Question about LG 42LC2D 42 in. LCD HDTV
Picture is frozen but the sound is working.
Remote only will work to turn off the TV. Sound is working ok and continues but the picture stays frozen
  • Anonymous Jan 11, 2009
    My problem is exactly the same as Aaron's but the model is 42PV1DV plasma screen. I have tried disconnecting the power and then restarting but problem remains. Rod.
  • mhall377 Jan 18, 2009
    Had similar problem some months ago and in desperation changed batteries on remote, presto it worked until today when if froze again. I changed batteries but no joy, unplugged and left off for today, seems oj for now. BTW the child lock was not on!!!
    Champion:
  • 211 Answers
I'll think that your TV has the child-lock (parental control) switch on.
You can change that in the menu.
I'll hope this works out for you.
Kind regards,
Gerard
Posted on Jan 11, 2009
Sound but no picture
Hello!
Does sound comes out of TV speakers? Or you have "home theater" hooked up to?
In first occasion: TV turns on, stays on, display blinks once, then nothing?
Inverter is at fault. Second occasion: TV turns on, stays on, display glows dark, sound OK, no picture: T-con board at fault. Third occasion: TV turns on, shuts off, sound is coming through "home theater"-OK. Power supply or inverter, or T-con are at fault. TV need major diagnostics and repair in every case. Let me know if you can handle that. Will guide you through the process.
Thanks,
Alex.
Dec 15, 2011 | Toshiba Televison & Video
Screen is frozen on with no picture and no sound. Does not respond to either remote control or manual controls. The tv did work and then after a few minutes went frozen.
You need to move further south if it is frozen. It's cold up north :-)
If you've pulled the power from this tv (power cycled it) and it still has this problem ... frozen with no picture and no sound. How a screen can be frozen with no picture, I'm not sure. But it sounds like you are going to be on your way to the repair shop. Or to buy a new tv.
If I couldn't see and couldn't hear, how would I know you were even here?
Nov 22, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
I have a Polaroid 37" LCD TV (FLM3732)
it could be 2 caps on the power board, i had the same problem and for $3.39 at Radio Shack solved it.
There is a link on hre with pictures and instructions from stiv0, that works. Of course your on your own if you try it.
Sep 30, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Need a lil help with a TP3285 C129
The tv is on Mono and wont budge there is a picture but not sound no remotes will work..wont even turn off by the base or remote its frozen. what do i do.. I dont even know how old it is..
Dec 14, 2008 | Philips Magnavox TP3285C 32" TV
Picture on TV stuck on one picture
Ok fixed it. Just unplugged the box and plugged it back in and it works fine.
Apr 05, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
396 people viewed this question
Computer Repairing
Computer Repairing
