Question about Brother HL 1650 Laser Printer
Hl 1650 printing dark (!) pages
When printing, the entire page has a gray background - what can be the cause of the problem? The output is unusable.
Replace the toner cartride. I just had the exact same problem, and this cured it instantly!! Bob K.
Posted on Jul 05, 2007
  • 705 Answers
Print Quality Issues
Posted on Jun 08, 2007
  • Inky Fingers
    Inky Fingers Jun 08, 2007
    Solutions for dark
  • Inky Fingers
    Hi J
    This sounds like either the density setting is set too dense (dark) or the EP-ED Cart is worn out.
    The cheapest fis to try first is the Density. Use the panel buttons to navigate to the density setting and see what value it is set to. If it is set dark, simply set it lighter.
    If this has no effect the most likely cause is the photo conductive typr unit is worn. If you have a new or old unit, swap it over and see if the image changes. If it does change, this would confirm the suggestion.
SOURCE:
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
Apr 27, 2015 | Ricoh Aficio CL7100 Printer
I am getting gray background when printing pictures why?
Can you see the entire page when you issue the PRINT command. Are you using Windows. If you are trying to print a picture from a website, you firstly need to take a snapshot of the entire page by holding down the left ALT key and pressing the key marked PrintScreen (usually located below F10,11,12) on your keyboard. Then use an Image editor to cut out the picture and then PRINT it.
Oct 14, 2014 | Epson Stylus Photo RX520/RX530
What might cause my Brother HL-2040 to leave black blotches and an overall gray appearance on print outs?
if your drum is new and still you are getting a problem of dark background then you have to replace the toner cartridge.
Jul 26, 2014 | Brother HL-2040 Laser Printer
The pages have a very dark background and it is in the pattern of wide stripes
Open rear cover and check gray plastic film not torn or broken. If film broken printer requires the fuser replaced. This is not a user replaceable item as its quite a tear down to reach the fuser.
Image defects may also be caused by toner cartridge. Check toner cartridge for background issues. To do this print the printer's demo page and open door when paper is half in the printer. Remove the paper jam and check unfused image for defects. If defects occurs then replace toner.
Mar 29, 2010 | HP LaserJet 3330 All-In-One Printer
Prints pages with dark background
Pull out the Toner Cartridge and clean its drum with a Soft Lint Free cloth. Hope your problem will be solved.
Jun 06, 2009 | Brother HL 1440 Laser Printer
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
May 17, 2009 | HP LaserJet 1020 Printer
Dell 1815dn laser printer prints completely black pages
1. Charge – Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn’t clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS – High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Apr 16, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
Brother HL 1650 Laser Printer Logo
410 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
