Question about Refrigerators
Toshiba GR-RG68MDA automatic ice maker not working
This is a totally new refridgerator, the automatic ice maker not working, the water below unable to go up to the freezer
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
  • 72 Answers
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
  • 153 Answers
SOURCE: Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Posted on Jul 21, 2009
martineznoe8
  • 92 Answers
SOURCE: There is water leaking below
CHECK INSIDE THE FREEZER COMPARTMENT BOTTOM IF THE EVAPORATOR DRAIN IS PLUGGED OR ICE UP IF THAT IS THE SITUATION GET HOT WATER TO MELT THE ICE ON THE DRAIN.
Posted on Feb 18, 2011
I was told that my new refridgerator will come with an automatic ice maker. What does that mean?
These days, modern fridges come with automatic ice makers that are built into the fridge itself. The fridge automatically fills the ice holders with water that then freeze into cubes. You can then tip the ice onto a tray that is removable and then the fridge will automatically re-fill.
Feb 18, 2013 | Home
Blank screen on gr l 247ni refrigator how to repair
Faulty control panel.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
My Whirlpool refridgerator has water in it. Where could it be coming from and how do I fix it.
Water must be getting melting from freezer section/.See if over ice is getting collected in freezer vents and freezer walls.
These will help.
Thanks,.
Dec 21, 2012 | Whirlpool Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice Maker
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Ice maker doesn't work
When you say you are getting water do you mean you are getting water in the ice maker tray? If so then unfortunately you will need to replace the ice maker. If not getting water to the ice maker then make sure the fill tube to the ice maker isn't frozen shut. If so, thaw it out and see what happens. If it isn't frozen shut then replace the ice maker. New ge ice makers, when installed, will not cycle until the ice maker gets below freezing so you will have to wait once it is installed.
Oct 07, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
