How to operate hotpoint 120 portable Aircon keeps cutting out
    Genius:
  • 1,669 Answers
Is it blowing the house breaker? If so, then the circuit is overloaded in the house. If that is not the case thethermostat on the AC unit needs to be replaced.
Posted on Jan 01, 2013
Keeps tripping the electric mains replaced element but still does it HOTPOINT
Try increasing the ampere rating of your breaker or remove other load(i.e. aircon unit, water heater, washing machine etc.) when dryer is connected so as not to overload your breaker that is causing mains to trip. If previously you are using the dryer with the same setup and loads maybe the breaker is the problem.
Jan 19, 2015 | Hotpoint Dryers
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
My AlP-12000 EH Portable Air Conditioner blows hot air
dear sir
please test your aircon with digital temperature meter i mean take first room temperature data then check your aicon flow air temperature it should be lower than to 20-22 degree Celsius if it,s not low like this
then it can be low freon problem in your aircon system.
thank you
hope answer the question
Sep 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
120 series prado diesel d4d aircon and indicators not working
Have any luck with this as I have exactly the same problem except the ign2 fuse under the dash also keeps blowing. Alternator does not appear to be charging either.
Feb 07, 2010 | 2007 Toyota Land Cruiser
Tank pressure 120 regulated pressure 200. how can
If your pressure cut-off switch is faulty, it will keep running. Could be very dangerous. MSC has switches with different ranges. I had this problem once with an 80 gal. compressor. It was running and I cautiously walked over and shut it off. At this point it had 200psi built up. Yes, I was scared but a new regulator fixed it. The old contacts were rusty and wouldn't release. Hope this helps.
Terry
Nov 18, 2009 | Dewalt D55146 Factory Reconditioned 4.5...
My portable air compressor turns on but wont turn
Check the operation of the relief valve. This is usually located near the regulator and gauge and has a small ring that you fit your finger in and pull outward. When you do so, compressed air should be released. If this is stuck or cant be released, there is your problem. It is quite dangerous to let the tank reach pressures beyond that allowed by the relief gauge. Usually 120-150 PSI.
Mar 06, 2009 | Coleman Air Tools & Compressors
Our Mitsubishi FDC506HES ducted air conditioner keeps shutting off on hot and cold after about 10 minutes and flashes and the comes up with the error code E3.It will heat for those 10 monutes before it...
Try to reset the error by disconnecting the circuit breaker for 10sec. and "on" again then operate the unit. But if wont work may there some parts that are defective that trigger the error E3. Replacement of pars is needed for this problem.
Sep 22, 2008 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
