Question about Samsung LE32A457 32 in. LCD TV
What is the aerial connection of sumsung LE32A457C1D
VW Polo 1.0 1999, Aerial not working
It is usually best to check an aerial from the radio end with an ohmmeter or continuity checker. The aerial cable is a coaxial cable with a centre core that carries the signal and an outer braid that when properly grounded keeps interference to a minimum.
Measuring between the centre and the outer there should be an infinity reading on an ohmmeter, indicating no short circuits in the cable or aerial base. Measuring between the outer and a good ground the reading should be very low, no more than a few ohms indicating a good ground connection to the aerial base and of the aerial base to the bodywork.
The next test is simple and tricky at the same time as one lead of the meter will need extending. Remove the aerial mast and test for a very low reading of just 2 or 3 ohms between the cable centre and the stud or socket where the mast mounts. If all tests are fine it indicates the mast has an internal fault. If the tests aren't fine the cause is fairly intuitive.
To some extent you can perform the tests at the aerial base but the results will be limited due to the physical connection between the cable and aerial base won't be part of the test.
You need to be aware some installations are fitted with an aerial amplifier which can confuse matters and make checking more difficult.
Jul 03, 2017 | Cars & Trucks
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
My Samsung LCD LE32A457C1D wont find any services please help
Hi there Convince yourself that all cords and plugs are where they should be. Especially that the input is correct. If you have HD then it is best to use HMDI connection. It should also work with the scart connections in the right place. It usually says on the cable and the port. Godd luck Kolbrun
Jun 24, 2012 | Cell Phones
Have somehow lost all our digital channels & when I try to rescan them it still doesn't work
Sounds like an Aerial fault. Obviously, the first thing you should do is check the the aerial connection to the TV.
Simple test for the aerial is to connect another television to the aerial connection for the faulty TV. If the second TV is OK, it's a faulty TV. If neither work, it's an aerial or aerial cable fault. If you don't have a spare to test with, can someone loan you one for a short time?
If neither work, check the aerial itself? Has it moved in the wind? Is it still pointing the right way (towards your transmitter). Has an element (one of the metal fins) broken off?
Try this and post back.
Oct 16, 2010 | Televison & Video
How to hook antenna to tv?
optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. the exact type and positioning of the aerial will depend upon your particular area your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable,turn off all main power switches. vhf or uhf it must first go to the media box and you will see the input aerial cable connect it there and the output go to the back of your tv that indicates aerial input terminal.
Oct 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have mobile phone model samsung raga SCH-B239. now iwant to the modem driver. whether it will work for internet connection?
if i got you right you want a pc suite for your sumsung phone. You can try (sumsung SCH-B239 pc suite free download) with google search engine and it will give you sites where you can download.
Again, you can go to sumsung.com
Aug 05, 2010 | Computers & Internet
Tv with built-in digital tuner not receiving any channels
Is your outdoor aerial a proper freeview aerial and are you in a strong or weak signal area.You can check here:http://www.stevelarkins.freeuk.com/freeview_digital_tv.htm
Also check your connections as the coax may be shorting with the braid or a bad connection.once checked try ordinary channels on upstairs tv and if ok retune all your digital channels.
This can be due to a few problems.Firstly make sure your aerial is pointing in the right direction as beam aerials attenuate(disregard) signals which are not pointing directly at the aerial.
make sure you are using good quality 75ohm cable i.e rg6 and connections are good and not shorting out.
The length of run of the cable will also affect the signal as will any splitters or joins in the cable.
If you know the signal is good in your area then it will be down to the aerial,cable terminations ,aerial position or a combination of these.
If the signal is poor you can either...Buy a high db gain arial which will amplify the signal and or a masthead preamp which will again boost the signal.
please note that if your aerial is not pointing in the correct direction then any boosting of a bad signal i.e ghosting...will only make it worse.
try starting from aerial direction then connections then a high gain aerial and or booster.
Oct 14, 2009 | Televison & Video
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Can't heat radio
Hi There Laura,
For you to get radio reception then you will need an aerial...
The FM stations are very weak and thus need a good long aerial to collect these weak signals.
Some receivers need the aerial to be a "loop" so and on the rear of the receiver there will be a special two port aerial connector for the FM..
You dont say where you are but if you are in the "outback' then a good long aerial will be needed...
The same can be said for the AM radio signals these are much lower in frequency but still need an aerial.
There is a difference with the AM signals as they also need a good earth as follows.
On the back of the receiver there will be an aerial connector marked AM and it will show an earth connector and and aerial connector.
There needs to be a good earth connected to the earth connection and another long wire connected to the aerial connector.
The earth should be a metal spike about 500mm long driven into the soil outside in the garden
and connected to a wire which comes inside thru the window to the earth connector on the rear of the receiver.
The aerial wire must not be connected to earth at all, but insulated.....
this wire connects to the AM connector out thru the window and up to the nearest high point. Like a tree or a pole...NOT A POWER POLE as that dangerous.
When you connect to the tree use a piece of plastic rope or something to insulate the wire from what ever it touches, as the radio signals are not allowed to come in contact withthe earth until they get inside the receiver...
You can use a wire with a plastic cover on it if you like..
You may wish to ask your neighbour if you can look at his aerial connections and learn how its done...
He wont mind.... unless you are "outback" and the nearest neighbour is 100miles away..
That makes it more difficult.
If you get stuck ask here again and I'll pass on more detail for you..
Cheers for now
From YUBEUT..
Apr 29, 2008 | Durabrand W600 Shelf System
Samsung LE32A457 32 in. LCD TV Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
