Question about Sharp 27F-640 27" TV
My tv will not turn on
When i push the power button all i hear is a click on and click off. the tv was working fine when it just turned off and will not turn back on
    Champion:
  • 240 Answers
Your tv set is in auto protection mode.
sum times its due to a power line falur or a power surge to the set and other times its due to parts failing inside the set.
depending on the age of the tv, you might want a repairment to take a look at it.
best regards,
daniel.
Posted on Jan 11, 2009
My LG Plasma 50PK550 doesn't show a picture when I push the power button. It will also shut off when I push either the Input or channel buttons.
Main digital board fault. Check and replace the main digital board. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 27, 2017 | LG 50PK550 50 HDTV Plasma TV
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
I have a Sony NSX-40GT1 that won't power on. You can hear the relay click after plugging in, and the red power led comes on, but when you push the power button it does nothing. Any ideas?
I'm having the same problem. Can anyone help. If possible i'd like to fix it rather than go return it. It worked fine for a while and then suddenly started turning itself off. Now every time i turn it on it turns itself off.
Jun 12, 2011 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
TV turns on sometimes
Maybe they got an electhrolitic capacitor near the horizontal side of the tv maybe about 250 volt to 1 mf or more
Apr 12, 2010 | Zenith B27A11Z 27" TV
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
My sony trinitron won't come on
From your description it sounds like you TV is experiencing a shut down and re-set condition. This is usually caused by some type of voltage irregularity in the power supply section of the TV. Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the set. Keep in mind that TV components are most prone to failure during the electrical surge when you turn the TV on. So constantly pushing the on button will accelerate a permanent failure.
Aug 28, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sharp 27F-640 27" TV Logo
128 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
