Question about Kitchen Appliances - Others
How to sharpen the blade of Graef meat slicer
SOURCE: Globe Meat Slicer Model # 500
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Posted on Dec 24, 2008
SOURCE: Globe commercial Meat slicer
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at njrealestate@earthlink.net. Thank you
Best regards,
Scott
Posted on Dec 27, 2008
  • 20 Answers
SOURCE: Berkel 827 sharpener not working properly
Your grinding stone stud is more than likely frozen try and lossen it up with a little penetrating oil take the sharpener off and work both stone back and forth untill they are both spinnig freely and remember do not apply either sharpening wheel on the knife for more than 5 seconds at a time you can burn the wheel and then it will never get sharp
Posted on Jun 13, 2009
  • 44 Answers
SOURCE: to sharpen the blade of my meat slicer
The stone that sharpens the back bevel is used for more time, but use grind for minimal amount of time, 30-40 seconds sounds extreme to me. The stone for the top surface of the blade is only pressed briefly to remove the slight burrs from sharpening on the back side of the blade.
Posted on May 22, 2010
SOURCE: Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
Posted on Sep 15, 2010
Bolt and washer for rival meat slicer mod 1101e/3
Meat Slicer Parts ' eBay
www.ebay.com/bhp/meat-slicer-parts
  1. Cached
  2. Similar
Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage ... Rival Food Slicer Meat Motor Holder SCREW 1101E-5 Accessory Spare Part.
Rival Meat Slicer ' eBay
www.ebay.com/bhp/rival-meat-slicer
  1. Cached
  2. Similar
Vintage Rival Electr-O-Matic Deli Meat Food Slicer 1101E-2. $45.00; Buy .... Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage. $7.99.
Food Prep & Choppers - Rival Products
www.rivalproducts.com/...manuals/food.../food-prep-and-choppers-manual.html
  1. Cached
  2. Similar
HM-743 - Rival® Hand Mixer Instruction Manual · 1042-WN - Rival® Folding Food Slicer Manual · CN-742 - Rival® Electric Can Opener Instruction Manual ... rival meat slicer mod 1101e 3 Google Search
Dec 23, 2016 | Rival Food Processors
HObart MOdel 1712 Slicer Sharpener
The tw sharpener stones should be fixed with the screw provided to the blade
May 08, 2008 | Hobart A200 Stand Mixer
Meat slicer blade is wobbling
sometimes the blade doesn't go in quite straight loosen ti and see if it will reset flat not knowing make nor model cannot look for manuel
Feb 01, 2015 | Kitchen Appliances - Others
Meat slicer: when slicing our pork loin the meat will stick up under the blade at the bottom causing the meat to spin off the slicer?
The blade may require cleaning in between usage as the oils and sugars are solidifying on the blade from previous usage causing the meats to adhere to the blade when sliced.
Dec 22, 2013 | Kitchen Appliances - Others
Can't sharpen blade
1 of 2 problem exist, you need new stones, or the depth of your sharpener needs to be lowered to compensate for blade wear
Mar 27, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Sharpen berkel slicer blade
collee; take the blades to a machine shop or a small engine shop they will be able to sharpen them.
Dec 21, 2009 | Sewing Machines
To sharpen the blade of my meat slicer
Oct 09, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Feb 03, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Appliances - Others Logo
62 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
