Question about Music
Baldwin organ 626 volume
Volume problem
  • 5603 Answers
SOURCE: low volume allen organ adc 4600
IF the expression pedal uses a lamp and light-dependent-resistor, check for burned out lamp at the pedal.
Posted on Sep 08, 2009
  • 1138 Answers
SOURCE: In need of users manual for Baldwin Funster
Try asking here:http://organforum.com/
Posted on Sep 11, 2009
  • 5603 Answers
SOURCE: we just acquired a Baldwin
The scratching is just a bit noisy volume potentiometer, but it pointss out that the power amp is working...
Are you sure you know how to operate the organ? You have to select one or more instrument tab switches to get anything out.
There could be almost anything wrong, but likelly a vacuum tube has failed. Open the back and see what tubes are lit. PLEASE NOTE: There is high voltage in the unit...
PLEASE ALSO NOTE that some tubes have two sections and BOTH must be lit for operation.
Posted on Dec 28, 2009
  • 5603 Answers
SOURCE: Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Posted on Mar 10, 2010
djlaplaya
  • 74 Answers
SOURCE: Our Baldwin electric church organ is over 30 years
Probably worth getting a new one. Try the keyboards from yamaha, they have good organ sounds.
Posted on May 06, 2010
Lowery Promenade organ LX400.
Have you tried unplugging it for a couple of hours ?
Aug 29, 2016 | The Music
Where can I find a user manual for a Baldwin MCX 1500 spinet organ?
I have that organ (trying to sell it on Craigslist) and have the manual. I can make a copy of it and mail it to you. Cost would be $10. Here is the Craigslilst link, where you can see a picture of the manual.. Baldwin MCX 1500 Electronic Organ Digital Keyboard Orchestra
Sep 10, 2015 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
We just acquired a Baldwin "Fun Machine" organ model number 121F. It has all the lights that work but there is no sound when pressing on the keys. If you pump the volume pedal you can hear scratching...
Dec 28, 2009 | Music
Need owner's manual for Baldwin Cinema II organ
I have the original technical data for it, as if you wanted to build one yourself from scratch, but no owners manual. Did you ever find an owner's manual? Also, I have the organ itself.
Oct 07, 2009 | Music
Music Logo
56 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
