Question about KEF Audio PSW 2500 Subwoofer
Kef subwoofer cuts out at high volumes - KEF Audio PSW 2500 Subwoofer
    Scholar:
  • 65 Answers
I have experienced the problem of the output cutting out in a KEF PSW2500. I have also previously replaced C52 which is mentioned in previous posts and is the storage capacitor to power U13 that protects the speaker from direct current in case of fault. The problem of cut out at high volume levels occurs on my unit as follows: When the input level is high in bass content, regardless of the input level (VR1) setting on the back of the unit, the output has a loud pop and stops until power is recycled, or just pops loudly on peaks but will recover. If I remove one channel of the input the problem is much less apparent.
The previous C52 fix corrected the buzzing noise caused by the protection relay coming on and off when the capacitor was dry, but the new problem is slightly related as follows: The audio operational amplifiers (opamps) make up the filter and gain stages and are powered by a +/-15V supply composed of U14 and U15. If you measure the -15V output (this can be done without the speaker connected and using a VOM) you may see that its output will go to 0V during peaks or may lock at 0v while the +15V side is stable. If you do measure this, the result is that the output of the opamps will have DC on them instead of 0V, causing U13 to detect this and shut down the output to the speaker to avoid damage.
Cause: The cause of this problem is due to the lack of input capacitors in the original design, between the Vin pin and ground of the voltage regulator IC's which in some cases can lead to latch up of one of the regulator IC's; especially the negative regulator (U15, LM7915). This part is not defective, but just latching up due to instability in the design.
Fix: To fix this problem, you need to add some components as follows: For simplicity sake, I used the same 47uF/63V parts that are used in the C52 repair. You need to solder 2 pieces in parallel with Vin and ground of U15, making sure the minus side of the capacitor is to the input and the plus side is to ground. Secondly, you need to solder 1 piece to the Vin and ground of U14, where in this case the minus side will go to the ground and the plus side to the input. Note: If you get the polarity wrong, the capacitor will blow up due to overheating. The reason that you unbalance the capacitors, is so that you make sure the positive regulator comes on first and then the negative regulator second. This is well documented by the manufacturers of the parts so it is not new.
Since this instability may be due to parts ageing, you may also want to add 1 piece of capacitor at each side of the +/-15V connector on the preamp board side, which is labeled CN2. This will make sure the audio circuits still have a healthy filter on the supply to keep the audio nice and clean. Note that the ground is common between the supplies so CN2 is only 3 pins.
You can test the unit without the speaker connected first with some high level content while re-checking the 15V supplies. Both should be stable and the protection relay should only come on when powered up and stay engaged anytime there is music content. If that checks out, re-assemble the unit (remembering to connect the red and black speaker wires) and enjoy your new sounding sub-woofer.
Posted on Feb 17, 2015
  • Anonymous Dec 08, 2017
    I own KEF PSW 1000.2 sub and i have the same problem (bass cuts out around 40Hz). I disassembled the amp but I can't find Vin pin. There is even no space to place the caps or it would be instead JP-?
    Can you please specify me where exactly I need to place them? Thanks a alot.
    there is image of the board.https://imgur.com/a/QvjAc
2 Suggested Answers
SOURCE: KEF Subwoofer AV1 and KEF Activator. Need specifications
Unit is now 12 years old min. and no longer state of the art.... i offer $400
Posted on Jan 28, 2009
My kef subwoofer keeps making loud buzzing noise
Either you need new high quality cables,or your amp has output filter capacitor problems.
Aug 25, 2014 | KEF Audio Audio Players & Recorders
Subwoofer cuts out kef (2010)
a capacitor could be overheating and cutting out.then,when it cools you get sound again.this will go on and on until you take it to a tech to get fixed
Aug 04, 2013 | KEF Audio Audio Players & Recorders
KEF 30B SPEAKER CONSTANT BUZZIN
Check your grounding and make sure to remove any high voltage items around it or possibly crossing over your low voltage lines.
Feb 10, 2013 | KEF Audio 30B Speaker
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
Hello ! I'm not sure how to connect my kef psw 2500 sub to my yamaha amp. I've got a subwoofer out on my amp but there's 4 inputs on the sub and I don't no which one to use ! Please help as getting...
Just for clarity, I need to explain what the four inputs are on the KEF subwoofer. There is a left and right RCA input which is the input signal to the subwoofer and there is a left and right RCA output which is the High Pass output from the subwoofer.
On the back of the Yamaha receiver, you said you have a subwoofer output. This output is most likely the mono subwoofer part of the home theater system and can be used if you like. The left right signal input into the KEF is summed into mono so if you only connect one channel you will basically reduce the signal level by 1/2 (-3dB) but it will work fine.
Alternatively, if your Yamaha receiver has monitor out and monitor in, you can run the monitor output signals to the subwoofer and you can then run the high pass outputs from the subwoofer back to the monitor in. This will give you the subwoofer and provide a smoother signal matching with your audio system.
It is not always easy to connect the subwoofer up to an integrated receiver/home cinema system using the high pass channels of the subwoofer as you don't always have access to the analog output and input of the front channels. In this case, just use the Subwoofer output or just the monitor out only.
I hope this solution is helpful.
Dec 03, 2010 | KEF Audio PSW 2500 Subwoofer
I thinking of bying this Sub, but I have an old Yamaha RX-V660 receiver. Can I conect the Sub to that receiver and how?
Not very easily. Your receiver has no Sub Output. You really want a sub that supports hi-level inputs such as this: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-633
Then you can run your front speakers through the sub.
The Kef site hints it may be possible to run high-level inputs to that sub by using RCA adapters.
Aug 27, 2009 | KEF Audio PSW 1000 Subwoofer
Blown kef q55.2 tweeter, is replacement possible?
The tweater on my Q55.2 blew as well. I went into a shop in NYC and they tried to charge me $225 for a new tweater, so I took it home and called up Kef. They sent me out a new tweater for $35 and instructions on how to solder it in.
It took all of 10 mins to replace and they are working fine. I've never soldered anything before and it was simple.
Cheers
Martin
Mar 24, 2009 | KEF Audio Q55 Speaker
Jan 22, 2009 | KEF Audio AV1 Speaker
Kef subwoofer kht 2005:2
check for the connection og the main wire is cut.. or check the supply..
Dec 07, 2008 | KEF Audio KHT 2005.2 System
KEF Audio PSW 2500 Subwoofer Logo
175 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
