Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
My Frigidaire refrigerator (FRS20WNF)does not make ice anymore.
It still make the popping noises but nothing happens inside of the freezer/ice maker. The model number is FRS20WNF.
  • CAROLE MUHLE Sep 16, 2009
    WE HAVE A FRIGADAIRE REFRIDGERATOR I RPLACED THE FILLTER. BUT STILL CAN'T GET THE WATER TO COME OUT AND THE ICE MACKER IS SLOWING DOWN.
Did you check your copper line in the back
Posted on Jan 14, 2009
My frigidaire side by side is not cooling well anymore...10 years
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Frigidaire FRS26ZSG
My Frigidaire model number is Frs20wnf My refrigerator does not make ice. There is water in the door. I hear all of the sounds that it made when it was making ice.
first we have to manually see if we jump the water valve if there is water then. if yes could be the ice maker bad, if no could be the water valve or you water line is frozen inside the freeezer... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | Refrigerators
No water going to ice maker.
could be a kink hose is the leavel in the ice maker is down
Mar 13, 2009 | Frigidaire FRT21H8 Top Freezer...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
1,160 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
