Question about Westinghouse Refrigerators
How to remove cover in westinghouse fridge rj340m to get globe out
Need to get plastic cover off in fridge to take out blown globe?
SOURCE: Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Posted on Dec 12, 2007
  • 159 Answers
SOURCE: Can I drill a hole in the side of my westinghouse rj340m fridge .
the most fridges i have stripped the pipes are on the left hand side and the power wires on the right hand side but if the pipe is drilled thru it is only the oil cooled pipes it can be disconnected the important piper are at the back of the frige i hope this will help you
Posted on Jun 17, 2009
SOURCE: I need to replace light globe in westinghouse
I rang Westinghouse and they gave me the type of globe I needed.
Many Thanks
Posted on Aug 05, 2009
SOURCE: I need chiller and butter plastic compartment as
I rang westhouse and got it through them.
Karam
Posted on Sep 20, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Westinghouse frost free fridge with
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 23, 2010
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Westinghouse Fridge/freezer RJ340M. Not freezing cold.
Could be several problems, it may have a leak in the coolant system, the compressor may be bad, or the control system may be malfunctioning.
Mar 17, 2013 | Refrigerators
Westinghouse Aurora RJ442 how to remove the cover of the light inside the fridge?
A flat driver between the plastic cover and the fitting will lift the edge. Gently pull outwards and the tabs come out
Apr 27, 2012 | Refrigerators
Water is leaking from the inside.
This is the solution to a the same problem in a Westinghouse Freestyle refrigerator which is probably similar in principle. Basically the internal drainage system from the freezer is blocked. Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Jan 08, 2011 | Haier Refrigerators
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Nov 03, 2009 | Westinghouse Refrigerators
Jun 17, 2009 | Refrigerators
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
