Preventive maintenance time m2 & m5 on my di520
The copier i have di520 shows on screen preventive maintenance time m2 & m5 please tell me proper solution.
  • 300 Answers
SOURCE: Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Posted on May 18, 2008
  • 126 Answers
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Posted on Jan 07, 2009
  • 15 Answers
SOURCE: minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Posted on Apr 11, 2009
  • 170 Answers
SOURCE: preventive maintenance time code:M2
just enterto tech rep mode stop 0 stop 1 then select funtion then find maintenance counter then reset the maintenance counter
Posted on Nov 20, 2010
SOURCE: install preventive maintenance kit for Konica copier
f 51-3 konica minolta
Posted on Apr 06, 2011
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
May 10, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Konica minolta bizhub 215 showing maintenance call(m2) and service call
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Sep 18, 2013 | Minolta bizhub 180 Black and White Copier
Preventive maintenance time code:M2
Nov 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta Ep4000 show CodeM2
Mar 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
M5 on DI 620 !
tenes que entrar en: stop key,0,0,stop key,0,1. entras en Counter y luego en PM. Resetear PC Drum 1, PC Drum 2, PC Drum 3 y borras el M5
Jul 10, 2008 | Minolta DiALTA Di520 Laser Printer
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
77 people viewed this question
jasbo
jasbo
