How do I fix cerwin vega vs120 crossover
Where can I buy or get my crossover fixed
5 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
SOURCE: i have a set of cerwin vega ls-12 3way woofer works but tweeters
thanks for replying so fast "oilcitycompu", i will do that .will let you know if it worked , thanks
Posted on May 23, 2009
chrisreitano
  • 85 Answers
SOURCE: I was given a Cerwin Vega LW12 by a friend. It
phreewillie,
If you are certain that the problem is not with the speaker(s) the problem then sounds like an issue before the amp.
Did your friend have this issue? If yes, the problem is with the built in amp/crossover. If no, there is some kind of problem in your location.
The amp will not produce the popping sound even if the the amp has a problem electronically. The problem could be improper voltage, line noise, wire resistance or a grounding issue. The first two would be eliminated by using a line conditiner with a built in surge protector. The resistance and grounding issues would be associated with the wire connecting the sub to your electronics. It could be simply the cable connecting the sub has an issue, try swapping it with one that you know works fine. Are you using in wall wiring? Try using like stated above, a short known good patch cable. Sometimes the wire of choice during a installation will not work for that amp. Try taking that in wall cable out of the loop. I have seen just this problem in the past due to the type of wire used. A low cost way to eliminate the voltage issues is to try a different source of electricity by taking the sub to a friends house and see if you can reproduce the problem there.
-Chris
Posted on Feb 22, 2010
chrisreitano
  • 85 Answers
SOURCE: Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Posted on Aug 13, 2010
Replacement woofers for Cerwin Vega HED 3way 12. Can I use woofers from the LS Series?
Absolutely, as long as they are the same impedance.
If you are unsure, use an ohmmeter to check the static impedance of the replacement speakers, and be sure that it is with in 2-3 ohms of the listed impedance of the speakers you are replacing (otherwise, your crossover points will be wrong).
May 14, 2015 | Cerwin Vega Audio Players & Recorders
Where can i find an amplifier for a cerwin vega hts 12a
Subwoofer Plate Amplifiers
What you need is a plate amplifier. You'll get more bang for the buck by using an after market one. They are simple to replace. Dayton is a popular brand. They use an active variable crossover .
May 22, 2014 | Cerwin Vega HTS12A Subwoofer
I am interested in disabling my Cerwin Vega XLS-215 tweeter protection switch. I am well aware of the ramifications of this modification. Is it in the crossover circuit and if so could you tell me how to...
http://www.cerwin-vega-fans.com/forums/viewtopic.php?f=24&t=1611
If you have a look at the above link, there are pictures of the crossover as well as the schematic for the crossover.
you will see in the second photo there are two yellow discs attached to the circuit board. you just need to remove these discs which are PTC Polyswitches, and replace both of these with wire links.
Feb 06, 2011 | Car Audio & Video
I own a CERWIN-VEGA V-12S 12" Front Firing V
You may have only messed up the crossover circuit. Try changing the crossover frequency and see if hte behavior changes. If so, then the parts cost should be minimal. If the behaviorr remains the same, there will need to be more investigation done internally. This is not a problem that is likely to be easily resolved remotely. Can you update this with your location? I may be able to provide a recommendation for a service shop.
Dan
Jan 05, 2011 | Cerwin Vega V-10S Subwoofer
grady66,
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
No sound coming out of speakers on my cerwin vega
spurdoggg,
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
Cerwin Vega D9-E Speakers. Bad crossovers...I think. Fixable?
Crossovers are made with wire coils, electrolytic capacitors and resistors.
Capacitors may get leaky or blown with time and heavy use, and are quite easy to find, just be sure to use the same polarity, capacity and voltage rating and to respect the polarity if it's a polarized capacitor.
There may also be a burnt out resistor or a coil. Resistors can be obtained and replaced (same resistance and wattage) and wire coils can be rewound (same amount of wire of the same wire gauge).
Another possibility is a partially damaged wire on the speaker itself. This is the braided curl wire that goes from the speaker membrane to the cable connection lugs on the speaker armature, and it may be damaged at the membrane side or the lug side.
It usually happens from what you call "overcooking".
To repair this it will require some soldering skills, but it's a bit hard to solder that type of wire, as it tends to oxydize and is difficult to clean prior to soldering, it may be difficult to access it, depending on the speaker structure(an alternative to this is to replace the speaker itself).
There may be some physical damage to the membranes if the sound is present but is of a bad quality (a slightly damaged membrane may be repaired using some rubber glue, but it will never return the speaker to the original condition).
These are just some suggestions, hope they can help you get closer to a solution.
regards
3rq8 (triarcuate)
Jul 23, 2009 | Cerwin Vega CLS-12 Main / Stereo Speaker
Apr 19, 2008 | Cerwin Vega LS-15 Speaker
Cerwin-Vega EXL1000D Amplifier Broken?
Call Cerwin-Vega and they should offer a "Flat-Rate" repair for it. No matter what is wrong with it, for a flat rate, they will fix it. If not, most any repair shop should be able to. If not, heck, I'LL buy it off ya! (I love Cerwin Vega stuff...)
Sep 14, 2007 | Cerwin Vega EXL-1000D Car Audio Amplifier
Open Questions:
152 people viewed this question
 Grubhead
Grubhead
