My Sony DVD recorder won't load. It leaves message on time and date screen ",D32767
I've tried the Input selection on the TV, but nothing shows on TV except top of screen "AV1" which disappears. Pressing the system menu button turns the machine off, no date or time appears. but the disk tray opens. Any solutions? Thanks, Rob
spare_head_2
  • 47 Answers
SOURCE: Locked dvd tray.
Hi SoraTotoro,
This sounds like the child lock has been inadvertently activated . Look through the manual to find the key combination to unlock it.
Hope this helps.
Spare head 2.
Posted on Jan 06, 2008
  • 4 Answers
SOURCE: disk unkown error message
If other dvds play then try getting the same movie but from another supplier if it persists the check yo dvd if it uses a dvd ROM then replace it with anew one.
thanks
Posted on Apr 05, 2008
SOURCE: DVD tray will not open
I had the same problem - unplug first- it is easy to undo all 6 small screws - open it up -plug in and then you can give it a little help to open it. It worked for me, BUT now it will open and close but not play the dvd.
Posted on Jan 20, 2009
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Posted on Feb 24, 2009
  • 108 Answers
SOURCE: I can not select input source, even though AV1 is
Press INPUT repeatedly to select the external input
to record from.
AV1: Audio/Video Input mounted on back panel.
AV2: Audio/Video Input mounted on front panel.
DV: DV Input mounted on front panel.
DV IN jack.
This recorder is only compatible with DV-format
(DVC-SD, DV25) camcorders. Digital satellite tuners
and Digital video recorders are not compatible.
Make sure your cables are connected correctly, if an audio cable is plugged into the video the unit wont see it.
Posted on Sep 06, 2009
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Trinitron tv won't come on. says please wait
There may be a issue with the tuner on the set but there is a way around that.
With a cable box with audio/video out jacks connect to the same kind on the rear of the set---go to that input on the set and should see picture and sound---leave set on that input and change/select channels with the box.
Nov 02, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My Sony RDR-GX300 DVD Recorder is suddenly only recording the 1st 15 seconds from the DVR. The entire show is on the DVR. I have tried discs that I've used before successfully & new DVD's.
1) pass the Disk cleaner buy to some radio schack, and test it
2) test the cable in another device, and determine if faulty or not.
3) if not clean the terminal from DVD VS TV with c.cleaner
4) otherwise the Syscom inside and another associates circuit is faulty such like record ampl.
go to the repair shop for fix it.
God bless you
Oct 01, 2012 | Sony RDR-GX300 DVD Recorder
I have just bought a new PD-DVR100 DVD recorder and am trying to use it but when i press setup nothing else shows for me to make any settings.
I'm sorry for the difficulties you're experiencing in using the DVD Recorder. Based on the information you have provided, please follow the below troubleshooting steps and check the operation:
Please make sure that the connections are secure and proper. (You have not mentioned the type of connection that you're using to connect the Recorder to the TV. You may use Component, S-Video or Composite Video connection to setup the Recorder with the TV).
Please make sure that you have selected proper input on the TV to view the setup screen of the Recorder on the TV screen. (Most of the TVs have an INPUT button or TV/VIDEO button to change the input. If you're not sure with the input selection method, you may refer the manual of the TV or get back to me with the exact model # of the TV so that I can help you with INPUT SELECTION)
Turn off both TV and Recorder and check the operation.
Unplug the Recorder from wall outlet for more than two minutes to perform a Power resetting and check the operation.
Try connecting the Recorder to the TV using a different cable.
If the issue persists, please get back to me with more details about the issue like the type of connection and model # of the TV etc.
Thanks for understanding. Please let me know if you require any clarification on the provided steps.
Oct 26, 2011 | Protron PD-DVR100 DVD Recorder
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
