Question about Toshiba 65HM167 65" Projection Television
My toshiba 65 hm 167 is showing "error" lamp door open, however, a repair tech said the door is not open.
2 Suggested Answers
  • 668 Answers
SOURCE: I have DLP 65 HM 167 I just changed the lamp Y67,
If these are little dots/pixels that are one color or black, I believe it is the optical block that is the problem. Unfortunately, the cost of it is the most expensive part in the set. With the cost of parts and labor I estimate it costing around $800.00 to $1200.00 to repair. With the cost of LCD units coming down in price, It hard to invest that much money into it.
I hope this helps,
Skyassoc
Posted on Dec 15, 2010
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
Changed 6 lamps y65 none work can they all be bad
Sounds like the circuit that is responsible for sparking and maintaining the voltage to the lamp has gone bad. It's called the Lamp Driver.
Don't waste any more money on lamps. Get a tech to have a look at either repairing or replacing the lamp driver.
Sep 13, 2014 | Toshiba Televison & Video
Tv is say lamp door open
Remove the lamp door and inspect the door switch. You probobly didn't get the door seated correctly.
Mar 21, 2013 | Toshiba 65HM167 65" Projection Television
How due you replace the lamp in the Toshiba Toshiba 65HM167 65 in. Television
Pop off the front panel below the tv screen. Remove bulb cover door (screw) and then remove the bulb housing. Replace with new bulb and reverse the process.
Thank you and best of luck!
Jun 06, 2011 | Toshiba 65HM167 65" Projection Television
My machine toshiba e studio 167 showining error code 1 side cover open .but i checked their is not open any cover even frout & side cover .so plz give me a solution as soon.
hai friend it is a small problem ,. the problem is Sensor is not working. U have to do one thing
open right cover., and clean the roller dust., and rearrange all the doors in the printer,. then close tightly the main door., and put a support for not opening ., try it it will work.,
May 10, 2011 | Toshiba E-Studio167 Copier
I have DLP 65 HM 167 I just changed the lamp Y67, I still have pin holes in ther picture what could be causing this
I hope this helps,
Skyassoc
Dec 15, 2010 | Toshiba 65HM167 65" Projection Television
AN SC547 ERROR ON MY RICOH AFICIO MP C3000 MACHINE
547 D Zero cross error § The zero cross signal is detected three times even though the heater relay is off when turning on the main power. § The zero cross signal is not detected for 2 seconds even though the heater relay is on after turning on the main power or closing the front door. § The detection error occurs twice or more in the 11 zero cross signal detections. This error is defined when the detected zero cross signal is less than 45. § Defective fusing lamp relay § Defective fusing lamp relay circuit § Unstable power supply 1. Check the power supply source. 2. Replace the PSU
Aug 26, 2010 | Office Equipment & Supplies
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba 65HM167 65" Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
