Question about Samsung LN-T3253H 32 in. LCD Television
What use for this chip 500765RT
Model CT21A530FL
    Master:
  • 879 Answers
Check this link for details
Posted on Dec 01, 2012
Lower porsion is black sounds ok CT21A530FL what is the trouble can help please
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 30, 2016 | Televison & Video
Samsung crt tv model CT21A530FL, audio is ok but retraced line only
Sounds like chroma IC fault. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jan 06, 2016 | Samsung Televison & Video
How can I disable auto shut off
Just note the chip number and Google it for the data sheet.
when you found the actual data sheet read the pinout diagram of the chip to find out the Vcc pin.
you have to cut the link of Vcc pin of the chip and the chip will stop working.
Feb 15, 2014 | Softheat Heating Pad HP218 12 3P
My machine model AR5618s error code 2 and F than
f2 mean toner chip disable.You should buy new one cartridge.There are easy to get only chip,please buy new chip and assemble this chip
Oct 20, 2013 | Office Equipment & Supplies
Hooking power supply back to desktop gateway computer 310 series after changing motherboard need diagram where can i get one
Let me look around for you.
The plastic front of the computer is the Front Panel. The area of pins on the motherboard that the wires from the Front Panel attach to, is the Front Panel header.
Sometimes there are two Front Panel headers.
This information may be tough to find.
What is needed is the manufacturer name and model number, off of the motherboard.
There were several different motherboard manufacturers used, and several different variations.
I'm going to post two links that may help you with identifying the motherboard manufacturer, and model number.
Look in the middle of the motherboard, around the edges, and in-between any expansion slots on the motherboard, for identifying nomenclature.
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWTHRASHER&eq=&Tp=
http://www.pcpartsohio.com/gateway.aspx?c=2&s=91
Going further, there is a motherboard chipset on the motherboard.
The motherboard chipset consists of the Northbridge chip, and the Southbridge chip.
The Northbridge chip will be covered with an aluminum finned Heatsink. It's identifying model number/letters will be covered.
The Southbridge chip usually does not have a Heatsink. It's model number/letters will be easily identifiable.
The Northbridge chip and Southbridge chip are installed in a mated pair.
A specific Southbridge chip will be used with a specific Northbridge chip.
This means that identifying what Southbridge chip is used will lead us to what Northbridge chip is used, without removing the Heatsink off of the Northbridge chip.
This shows you a motherboard diagram, detailing how the motherboard chipset is connected to the rest of the motherboard,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
This general example of an average motherboard shows you the Northbridge chip, and Southbridge chip,
http://en.wikipedia.org/wiki/File:MicroATX_Motherboard_with_AMD_Athlon_Processor_2_Digon3.jpg
Looking in the middle of the motherboard you will note a bl;ack square Heatsink that looks like a meat tenderizer.
This is the Heatsink over the Northbridge chip.
To the left of the Northbridge chip, and to the left of the ram memory slots, is the Southbridge chip.
It has VIA on it in white letters.
State any identifying letter/numbers that you see on the motherboard.
Please state in a Comment.
Regards,
joecoolvette
May 29, 2011 | Computers & Internet
Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 29, 2010 | Mitsubishi WS-48315 48" Rear Projection...
I am looking for a replacement power chip for the hikona tc1400 tv/dvd combo the numbers on the chip are 500765rt a cross reference number would be helpful and where can i get one im in the uk
You can try www.partstore.com in the UK I do not think there is a website for that. but you can try the website I put above.
Thanks I hope this was Very Helpful for you.
Dec 10, 2009 | Televison & Video
Model 53UWX103B - parts 21 chips for converters to
This is a model that uses either the STK-392-110 OR STK-392-150----BOTH are the same part but the 150 chip lasts longer.
Most of the time the "kits" are a waste of money--unless something unusual has happened you will just need a pair of the chips and maybe one resistor.
There are several resistors around them that can fail if a chip shorts. The kits average 40-80 dollars but you can buy a pair of the 150 chips on EBAY for about 13 dollars plus shipping.
Let me know if you have specific questions or need advice--I am here to help.
SD TECH
Magic Singalong Song Chips - question please
Not exactly, magic sing comes in different models with different song chip. Old magic sings uses Black with metal song chip, Black song chips, Silver song chips and Gray song chips.
For your Magic sing II (I believed it has four song chips slot) the compatible song chip is the Silver song chip.
Oct 26, 2008 | Magic Sing Along Consumer Microphone
Samsung LN-T3253H 32 in. LCD Television Logo
253 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
