Question about Everex NM3500 Laptop
Everex NM3500 is dying?
Well, first, the AC charger quit working so I paid 90 bucks for a new one, that worked fine for a couple of days, now, I can't boot up, NO VIDEO!! intermittently, it has booted to a blue screen, and mentioned a memory dump? whats going on? is it DEAD???
I just bought a used Invacare TDX SI2 powerchair. The batteries hold only about a mile's worth of power; and now the charger is not working. No lights when plugged into the wall.
If the batteries truly are new, it could be since the charger was defective it wasn't charging the batteries properly. You can buy a three stage charger designed for gel batteries for around $30 bucks on Amazon. If it is the batteries I am afraid they are quite a bit more for replacement than the charger itself. Good Luck!
Dec 04, 2016 | Cars & Trucks
Bought the rechargeable light new a couple years ago, used one time for about 90 seconds. Went to use it again, it was dead. plugged in the battery charger into the cig lighter and it worked after 5 min....
First, ensure the charger is delivering voltage using a volt meter. If it is, the battery is probably bad. If you have soldering skills, the light can probably be disassembled and a replacement battery can be purchased from Radio Shack or online.
Jun 29, 2011 | Camping, Backpacking & Hiking
I have an everex nc1500. it was on working fine, then it suddenly went dead like it was on battery,(but was on charger). now no lights come on ,it doesnt charge, doesnt try to turn on in any way. it acts...
This seems like a poor soldering job at the factory which has become loose/disconnected over time, affecting the power port the ac adapter plugs into. Take the laptop to the shop and have your power jack inspected.
Mar 10, 2011 | Everex StepNote NC1500 Notebook
My Everex 3500 motor is running but the screen is black
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Aug 27, 2010 | Everex NM3500 Laptop
Blue light special
I feel for you. HP makes a crummy product. That is why I never sell them anymore. Plus, as I do some warranty work for them, I get to see the problems up close. Their tech support usually sucks as well.
Jun 29, 2009 | HP Pavilion dv9000z Notebook
My audio doesnt work when i upgraded
Go into Control Panel --> System --> Device Manager. Look for a Sound device or unknown multimedia device. Try updating the device to Realtek audio. Vista should have it's own Realtek audio drivers. If you can't find it, go here...
http://www.everex.com/support/nm3500w/nm3500w_downloads/nm3500w_downloads.htm
for driver downloads. Honestly, I'm not sure if the Realtek driver listed there is the proper one, but it's the only one listed. Post back with how it goes.
Jan 04, 2009 | Everex NM3500 Laptop
Durabrand moddur1800 9V 2.2 Amp
There are 3 or 4 chargers listed on ebay.
Jul 29, 2008 | Durabrand DUR-1700 Portable DVD Player
Everex NM3500 Laptop Logo
80 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
