Question about Sony Playstation 3 (PS3) Console
Disconnected ps3 from hdtv now using regular cables wont work now
Switched from high def cables to tv not equipped for high def so used red yellow white cables i know they are connected correctly what else could cause it not to work?
    Scholar:
  • 67 Answers
Nah your setting are good. What you do is turn off your console. Now turn it back on and hold the on button for three seconds it should beep. You should be sweet after this. It is just a stupid PS3 fault.
If this dosent work let me know if it does please leave feedback
Posted on Jan 11, 2009
PS3 used to work on TV in bedroom and on TV in lounge, now it won't work on TV in bedroom
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do:
1. Connect it to
your Lounge TV with an HDMI cable and a red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
cheers :)
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I borrowed my brother-in-law's ps3 while he was away for a few weeks. it worked fine on my tv but when he got back, it didn't work on his. i have an HDTV but he has a regular one. i've looked for answers...
Alright so this is what you have to do.
1. Connect it to your HDTV with the HDMI cable and the red/white/yellow cable.
Jan 10, 2011 | Sony Playstation 3 (PS3) Console
I turn on my playstation and it works but i got no picture or sound. Recently i took my playstation to a mates place. my tv is standard def. my mates is high def 1080p. when i connected my sony to my mates...
sometimes ps has this problem as i m also havin a ps2 n ps3 n i play them on my standard definition tv ....i also hav to restart again n again till 10 to 12 times then finally it starts this may be a plate problem go show it to ur nearest service center.......hope it works
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Xbox 360 sound but no picture can any one help
If you've just bought your xbox 360, then you probably haven't got a HDMI cable.
Which I think you could need.
Aug 18, 2009 | Microsoft Xbox 360 Console
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
No analog stations on my hdtv 37 inch, have no digal box just regular cable, regular cable works on normal tv
Try an antenna if you want to get analog over the air. I have a feeling that with the way the standards are changing, you will only be able to get digital channels. After February, the analog channels won't be around.
If you are using cable tv you need an HDTV box to get high def.
Jun 13, 2008 | RCA HD52W59 HDTV Projection Television
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
HDTV Problem
there shouldnt be a problem with the cable, if you use the component leads then you will not need to use the s video cable for video incase that is what you are doing, component only uses 5 connectors and the switch should be set at HDTV not tv and the tv set at component Use the following colours into your tv:- Green, Blue, Red and the audio red and white, you do not need the yellow or the s video plugs. Then select the 1080i when in the component setings on your tv and do the same in the dashboard settings
Jul 01, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
