Question about Garden
Why does my scott lawn tractor s1642 stop running after about 5 minutes?
    Scholar:
  • 144 Answers
Check your fuel cap. If it has a vent that isn't working, the fuel tank will build up pressure because no air can get into the tank and will then prevent fuel from getting out to the engine. You may need to replace the fuel cap. If so, you can get one at PartsBuggy.com.
Posted on Dec 14, 2012
3 Suggested Answers
jpmaly
  • 6 Answers
SOURCE: install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
Posted on Aug 30, 2012
mowerman1857
  • 389 Answers
SOURCE: I need a digram of replaceing a drive belt on
You can download the owners mqnuqal here:
http://dl.owneriq.net/2/2141e15a-36a6-9594-0166-6f10fba50f44.pdf
It has full instructions as well as diagrams
Posted on Sep 23, 2009
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Install drive belt for scotts s1642 rider lawn mower
Aug 30, 2012 | Garden
Works for a while and then stops
To rule out a fuel tank breather issue, just slacken off the filler cap so as air can enter the tank, if it carries on running replace with a new filler cap
May 14, 2012 | Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a digram of replaceing a drive belt on s1642 scott lawn tractor.
Sep 23, 2009 | Garden
Does scott mower #S1642 have a magnito? if so how do I access it?
no there is no magnito. what is the problem you are having, i can help you.
Jun 25, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
