Question about Neurosmith Together Tunes Soft Musical Cube by
Need cartridge for neurosmith together tunes cube
We have the original together tunes cube by Neurosmith and need the cartridge so it will sing (old mcdonald, etc)
2 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: The neurosmith block machine has stopped working
This is just because of the loose contact inside the board.There will be a spring loaded rubber pad behind the button board.Just open the case and remove it clean and place it properly.Have you poured water any time by mistake?Check on the board for water marks.Use the multimeter to check volts pass from the battery to the board.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 20, 2010
Tip
You can do the Bedlam Cube as shown on the Dragons Den
Thought I would photograph this to help me do this cube still have not got it back together since my 3 year old took it apart.
Here are the four sides of the cube completed to help anyone who needs to complete it before 2011..
http://www.facebook.com/album.php?aid=2044337&id=1301947832&l=bf5bd07bc6
Happy Cubing its listed in the Sports Locks section as you might need to lock yourself in a room for days so its a kind of sport.
on Jan 07, 2010 | Locks & Locksmithing
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Ice cubes stick together
have same problem with industrial ice maker machine at my work because the setting is too cold to let the ice cubes separate.
Apr 15, 2014 | Refrigerators
How can I get Singing Coach to run on my Windows 7 PC?
Hello.
Unfortunately, your software will not run on the Windows 7 operating system. The website for the manufacturer (Carry A Tune), doesn't appear functional. Often manufacturers will update their software for current operating systems, but not Carry A Tune.
Hope this helps.
Jan 05, 2012 | Linspire Carry A Tune Singing Coach...
How does this toy work?
From left to right you place blocks in any order and then press the little red button on the middle protruding section to make the device play sounds. Rearrange the blocks to make different sounds starting with the first spot on the left to make that blocks sound. I think you can even affect the tone that the block produces by which side of the block is face up; can't remember at the moment.
May 04, 2011 | Neurosmith ® Music Blocks®
Neurosmith Together Tunes Soft Musical Cube by Logo
140 people viewed this question
Top Neurosmith Toys Experts
Tom Chichester
Are you a Neurosmith Toy Expert? Answer questions, earn points and help others
