Question about Daewoo DTQ-25S3FC 25" TV
Daewoo tv power on but no picture
I can hear the sound but no picture on screen...the first times this happen i try to shake the tv and apparently the picture appear on screen then disappeared after 10 min .... what is the possible broken component that i need to check for make my tv looks like is new? tha angelo ciao
  • 934 Answers
Angelo, I've been in electronics more than 20 years and I still use the shake, rattle and roll method of testing. :) From what you've described you probably have a poor solder joint somewhere on the CRT board or in the vertical deflection. Turn it off, unplug it and leave it sit awhile. After a few hours you can remove the back and carefully inspect the CRT board. That's the little board you'll find plugged onto your picture tube. Be careful NOT to touch the printed circuits. But with your glasses on look at the solder connections on each of the components. If something looks like it has a tiny crack all the way around the solder connection remove the board and resolder that connection... if you find nothing there you can remove the main board and do the same in all the area around the IC's that have metal heat sinks attached to them... If you find something that looks suspicious carefully solder it up... With all that you should find the problem and if not button it up and take it to a repair shop. It isn't too expensive to have some poor solder joints repaired.. In our shop here it would be about a $60 dollar job plus tax. Hope this helps Bill
Posted on Jun 07, 2007
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
TV Picture Cuts Out
Sounds like you have bad soldier connections inside your set.
Mar 12, 2008 | Daewoo DSC-30W60N 30" TV
Daewoo 42
i wiuld guess that the power supply failed. thats the perfect discription of how it happens. find the board and install it. it should be easy.
Jan 20, 2008 | Televison & Video
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Daewoo DTQ-25S3FC 25" TV Logo
456 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
