Question about Shindaiwa Garden
Shindalwa blower only run for a few seconds then cut off
I pour gas into carberator choke it it starts only run for a few seconds and then stauls out stop running.
  • 257 Answers
SOURCE: Blower stall after few seconds
sounds like you not getting enough gas,or you are getting air in gas line,, check for air bubbles in gas line,, if you dont have any then clean the carb. good,, hope this help you
Posted on Sep 02, 2009
  • 49 Answers
SOURCE: snow blower is running sluggish with the choke in the on position
It sounds like you my need to rebuild and clean the carburator. Or you have an air leak between the carb and the cylinder.
Posted on Jan 29, 2009
bbreton
  • 437 Answers
SOURCE: mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Posted on Nov 02, 2009
  • 7 Answers
SOURCE: homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Posted on Nov 03, 2009
rwvanlue
  • 486 Answers
SOURCE: My ryobi pbc-3046YE brushcutter wont run.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Posted on Nov 10, 2009
Will not start it ran and juat stopped I can put gas in the choke and plug it will run for a few seconds and stop
Ethanol gas wrecks Carburetors and Gas lines. Just for giggles see if the Stone filter in the gas tank broke off the dried out gas line.
Jun 27, 2015 | Weedeater 25cc Gas Blower ()
Gas pouring into carb
carb float problem
Apr 22, 2014 | John Deere Garden
What should I do with my husqvarna 130BT because I put in too much oil with the gas and it won't start?
First, you need to dump all of the fuel out of the gas tank, Preferrably into a gas container. If you know how much oil you dumped in, you can calculate how much more gas to add. You could also just dump the gas, re-mix some new gas and oil, whichever you prefer.
If you are comfortable doing this, remove the fuel lines going to the carberator and let them drain into a pan. Pump the fuel primer to purge the gas out of the carburator, and then re-install the fuel lines. This might help you get it started a little faster, but its not necessary. You can burn the old gas in the engine at it will be fine.
Next, remove and replace the spark plug. Its probably fowled out with too much oil. Keep a can of carb cleaner and a small wire brush handy, you may need to clean the spark plug a couple times. If it gets too dirty, you can replace the spark plug with a new one. Do not burn Carb Cleaner in your engine for long periods of time, it will damage the engine.
After you have installed the spark plug and put some correctly mixed gas in the tank, Try to start the engine again. There will be some residual fuel in the fuel lines going to the carberator, so you will need to burn off that gas.
If you can't get it to start, try these steps:
Choke off, throttle wide open, crank several times. (or let it sit in the sun for a couple hours) (this corrects flooding)
Prime carberatur, Choke full on, throddle idle position, crank until it fires once but does not start.
Choke half, crank until it fires again or starts.
If it starts skip this step: (Choke off, crank until it starts).
Keep the choke on half for about 10 seconds and let it idle.
Put the choke off and let the engine warm up for a couple minutes.
After warmup, test the throttle to see if it will run at full throttle (it may take some fluttering until the engine is fully warmed up)
Let the engine run at full throttle for a few minutes. The exhaust may be a little more blue-smokey than normal...this is the excess oil burning...totally normal and harmless.
Mar 25, 2012 | Husqvarna Garden
We just bought an echo pb 250 leaf blower and can't start it at all. We bought one yesterday with the same problem and the people at home depot couldn't start it either. What are we doing wrong.
sounds like its not getting gas in the carberator yet. even though its new i would take off the air breather and pour a small amount of gas in airtake. this might get it started enough to prime the carberator and draw the gas on its own.
Jun 27, 2010 | Garden
My ryobi pbc-3046YE brushcutter wont run. When I start with choke it races for a few seconds then cuts out, if I get it started without choke it idles briefly then cuts out, if I try to accelerate it cuts...
1) spark plug
Remove Carburetor
Nov 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Mb 3200 gas leaf blower will start when choke
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Aug 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas leaf blower runs at half speed
First you will have to get a carburetor kit ,it consists of diaprams and inlet needle,you then remove the two srews that hold carburetor on the engine and remove gas lines,also the throttle cable remove screws that hold ends of carburetor on under these you will find the diaphrams and needle remove these be carefull not to loose the little spring under the needle lever.
!get you a can of carburetor cleaner and spray carburetor the blow it out with air you will notice little jets in carburetor that have to be clean use a wire from a bread tie to clean them out install new gaskets and diaprams in same position you took old ones off.you can also look at carburetor to see what kind it is walbor,zama,tilloson? type the name in google search and can get a diagram of carburetor if you loose your place,or just ask me.
May 15, 2009 | Homelite Consumer Products MightyLite...
2004 honda crf 150 wont start
how menney miles has it dun???check compreshon on bores.shoud be 110+psi 4 good running.
Apr 20, 2009 | 2004 Honda CRF 150 F
Garden Logo
43 people viewed this question
Top Shindaiwa Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
Are you a Shindaiwa Garden Expert? Answer questions, earn points and help others
