Sewing Machines Logo
A
Anonymous Posted on Dec 01, 2012
How do I change the light bulb on a pfaff 7540?
How to replace bulb onPfFF TIPTRONIC 2030
To change the bulb in the Pfaff Tiptronic 2030, you need the bulb remover that was in the original accessory package. Push the bulb remover up into the sewing machine (at the bulb) as far as it will go. Rotate the tool (and the bulb) one-half rotation counter-clockwise. Bring the tool and the bulb down and remove the bulb from the remover tool. To put the new bulb back in, put it into the diagonal holder until the pins engage. Push the bulb up into the lamp holder of sewing machine as far as it will go. Rotate the bulb one-half rotation clockwise. Remove the bulb changer tool. The bulb should remain in the sewing machine. This, https://www.sewingpartsonline.com/bulb-remover-412570101.aspx , may be the correct replacement for the tool.
Pfaff has many of their sewing machine manuals on their machine support page. The Tiptronic 2030 support is here: http://www.pfaff.com/en-US/Support/272 . The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Tiptronic_2030_2040-manual-EN.pdf?ext=.pdf . See page 139 (132 of the PDF) for the directions to change the bulb.
I hope this helps.
Where is the light on Pfaff 2029?
The light on the Pfaff 2029 is inside the machine near the needle threader. It's to the left of the needle bar near the front of the space behind the front cover. To access the bulb, first remove the accessory tray then use the bulb removal tool. Push up on the bulb as far as it will go and then rotate the bulb and removal tool one-half rotation counter-clockwise. To replace the bulb, insert the new bulb into the lamp changer and guide into the bulb housing. Rotate the unit one-half rotation clockwise. Remove the lamp changer and the bulb will stay in the sewing machine.
Pfaff has the manual for the Classicstyle Home 2029 on the product support site: http://www.pfaff.com/en-US/Machines/classicstyle-home-2029 . The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/ClassicStyleHome2029-manual-EN.pdf?ext=.pdf . The light position and replacement is shown on page 4:2 (page 45 of the PDF).
I hope this helps.
How do you open the sewing head to change bulb on Pfaff 955 hobbymatic
To access the light bulb, use the button-hole foot to lift up the insert on the arm cover. Remove the cover. Hold the edge guide slightly tilted and push it into the opening in the head of the sewing machine. Press down on the lamp housing to hold it still. Push up on the bulb and turn it counter-clockwise. Once the bulb is loose, pull it down and out of the lamp housing. To replace the bulb, continue to hold the lamp housing. Push the new bulb into the housing and rotate it clockwise. Release the lamp housing and then use the button-hole foot to replace the cover.
Pfaff has the manuals for most of their machines here: http://www.pfaff.com/en-US/Support-and-Updates/Support . The Hobbymatic 955 support page is http://www.pfaff.com/en-US/Support/3529 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Pfaff_935_955_HobbyMATIC-manual-EN-FR-DE-NL.PDF . See page 51 (page 59 of the PDF) for the directions to change the light bulb, These pictures may help you see how to get to the bulb. If you need a replacement button-hole foot, see http://www.sewingpartsonline.com/buttonhole-foot-low-shank-new-1932l.aspx .
I hope this helps.
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
2answers
No display
I have a Pfaff Expression which went the same way, but showed the error message "WD".
My dealer advised me to change the light bulb, which I've done, and since then its been fine.
Hope this works for your too.
All the best.
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
