Question about Refrigerators
I have a pure essence water cooler. who supplies the bottle rubber stopper
3 Suggested Answers
  • 14 Answers
SOURCE: advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Posted on Jul 10, 2008
  • 958 Answers
SOURCE: water is hot on both
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Posted on Oct 06, 2008
How to descale an water cooler pad?
Hello, Here is website for the recommendations for cleaning water cooler pad. How do you clean swamp cooler pad Ask com
Nov 06, 2014 | Windex Multi Task with Vinegar, 32 oz....
Oil in water bottle no emulsion no coolant loss could it be oil cooler
The only oil cooler in the radiator is for the transmission, check for loss of transmission fluid and water in the transmission.
If the transmission fluid is clean, try to id the type of oil present, if it's not redish color, you have engine oil entering the cooling system.
Water is heavier than oil, and will show if you unscrew the drain plug at the pan.
Jun 23, 2014 | 2002 Jeep Grand Cherokee
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
The rubber washer on the stainless steel plug has perished and therefore will not hold water in sink when needed.
Unless its really old, you should be able to find a replacement stopper at HD or local plumbing supply.
Apr 30, 2011 | Blanco Sink Waste Strainer / Stopper...
On my t reg citroen saxa i have oil getting into the cooling system car seems to run and start ok expansion bottle at side of radiator is collecting oil, oil on dipstick is clean. no sign of emulsion in...
does it have an oil cooler under the oil filter? (a lump perhaps half as high as the filter but a bit fatter with 2 rubber water pipes going to it) citroens are well known for these oil/water coolers leaking into the water.
Aug 19, 2010 | 1992 Daihatsu Charade
I was cleaning the water tank and i accidently knocked out the spring, tiny black plastic stopper and the white rubber washer, please could you help me put it all back together again, hopefully this can be...
Hi!
I've got the same problem and I managed to solve it.
So you have to put the plastic stopper to the buttom of the water tank in way that the wider end is down. You must hang the spring on the plastic stoppers narrow end so it would be placed between the water tanks bottom and the plastic stopper. Then you have to place the rubber washer from inside the water tank on the plastic stoppers narrow end. So would look like the following: plastic stopper -> spring -> water tank -> rubber washer
Jul 08, 2010 | Gaggia Caffitaly K111 Coffee Maker
GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
Jan 07, 2010 | GE Refrigerators
After emptying our water dispenser for cleaning,
Good luck.
leey05
Dec 07, 2009 | Hamilton Beach Water Cooler with Storage...
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Advise
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
