Question about Car Audio & Video
On the Jensen JTA-460 the volume "control" does not work. I have tried turning it on and off and chamging settings. How do I fix it? The volume wont go up or down.
josh1856
  • 105 Answers
SOURCE: Jensen JR500 Remote Volume Control
Try reprogramming the codes into the TV for the volume control.
Jensen JR500 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps! DONT FORGET TO RATE ME on FIXYA!
Posted on Jan 30, 2008
SOURCE: Jensen volume
turn the volume level to what you want, when you still see the yellow level on the screen, press and hold the volume button till you hear two fast beeps, this will be the level you deck will start of at every time you turn it on
Posted on Jul 28, 2008
  • 20 Answers
SOURCE: Harmon/Karden 2006 Radio/CB/CD Passanger control does not work
The passenger controls on the rear speakers are pretty easy to diagnose.  The wire for Volume up is Pink/white, the volume down is gray/white.  If the Pink/white wire is shorted to ground somewhere, then as soon as you turn on the radio, it will be like having the volume selector pushed up, and it makes sense how you describe it goes to mute and then returns to full volume as soon as you let go.   You don't say what model it is (I doubt it's a Road Glide, gotta be an Ultra), so it's not too hard to get at.  Pull the outer fairing and look on the back of the HK Radio.  There are 2 big connectors, when looking from the front you want the connector on the right.  Pin 23 is down volume, pin 34 is up volume for the rear controls ONLY.  So I would check the continuity to ground at pin 34 first, in other words pull the connector off the back of the radio, take a test lead and hook one end to +12v. Touch the tip to any grounded metal and it should light.  Now touch the tip to pin 34 on the harness side of the connector.  If the test light lights up, you have a short to ground on the pink/white wire.  Now go to the right rear speaker on the tour-pak and disconnect the 6 pin connector and try the test again.  The pink/white goes from pin 34 on the radio and runs through the harness to the passenger controls and nowhere else.  It shouldn't be grounded anywhere.  Let me know what you find out.
Posted on Feb 05, 2009
  • 8457 Answers
SOURCE: My olevia tv's volume is not working correctly. I
Maybe the remote or the tv manual control board is damage?Check the tv manual vol + - see if function normally.Take the remote aparts and clean it with some Q tips dip in with rubbing alchahol clean the remote PCB.Try website like Remotes.com to buy an exact to the original remote tv.
Posted on Jul 15, 2010
  • 3 Answers
SOURCE: Just received my Jensen JTA-460
There is a speed selector directly under the needle arm.
Posted on Sep 19, 2011
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
I wrongly plug jensen jta 460 turntable to 220volt power outlet. Can it be repaired? What is the dc out put of th?s power adapter? Can I change this original adaptor with 220volt ac dc adaptor?
Depends on how big it is, probably not, either the transformer coils might be burnt, causing a short (did you see or smell magic smoke?), or the diodes might be burnt (did you see or smell magic smoke?) or capacitors might be blown (did you see or smell magic smoke?)
As far as a different adaptor, see my response to your other question:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=25839291
Aug 27, 2015 | Computers & Internet
Jensen JTA-460 will not power ON?
It may start when the tonearm is lifted. If not, the turntable may have failed
Dec 26, 2012 | Jensen JTA460 Turntable
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
I need it now jensen jt a 460 turn table manual
Tech Help call 1800 686 079 Mon -Fri 9am to 5pm I have a JTA 380 Manual ? similar spec's.
Mar 11, 2012 | Jensen JTA460 Turntable
How can i fix my jta-460 from playing records slow
Check the RPM switch on the turntable is on the correct speed for the record you want to play. Otherwise it could be a belt problem internally.
Feb 13, 2012 | Jensen JTA460 Turntable
Loud switch
Call Jensen on this one. I have no idea as I don't one this unit.
Apr 28, 2008 | Jensen VM9510 Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
or
Sep 04, 2006 | Jensen JR500 Remote Control
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
