Question about Toshiba Satellite L355-S7811 Notebook
Toshiba satellite won't go on - Toshiba Satellite L355-S7811 Notebook
    Novelist:
    Champion:
  • 233 Answers
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Posted on Dec 04, 2012
5 Suggested Answers
drckzm
  • 243 Answers
SOURCE: my toshiba satellite laptop keyboard just quit and
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
Posted on May 12, 2011
  • 83 Answers
SOURCE: my toshiba satellite l455 won't start up it
click on F2 and that will take you to the Bios setup, check that your hard drive and Ram (Memory) are both online if all is ok and no problems press F12 it might take you to a diagnostic screen prompting you to perform a diagnostic test, if so do the tests and write down any errors given, if there is not diagnostic tool you might get the options to restor factory defaults this option will reset your computer to its original state and you will lose all your data. Another option if you have the operating system's cd (windows xp, vista etc) from the bios (F2) change the boot sequence to cd (just click on Cd/DVD Rom)only and reboot, windows will ask you if you want to repair, if all your hardware is ok and you should be able to solve the problem good luck and all the best
Posted on Jun 06, 2011
SOURCE: my toshiba satellite E205-S1904 won't
System: Toshiba satellite E205-S1904
Pre-Installed O/S: Microsoft Windows 7 Home Premium 64-bit Edition
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
    securityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, if you have UpperFilters, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, if you have LowerFilters, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Regards,
Deathschythe33
Posted on Aug 05, 2011
  • 144 Answers
SOURCE: Toshiba satellite C660 Won't boot. When I hit the power button showing a blinking cursor and not displaying the Toshiba logo too. please help me..
If it doesnt beep then you have a problem with your RAM or your motherboard. Try reseat your RAM first.
Posted on Oct 03, 2012
Toshiba Satellite A215
And that's the only issue your Laptop has? No messages that pop up or displayed as you try and run them? Vista OS, right? At this stage all I can think of another program is stopping them like Windows Defender? is that on your system and running/enabled if so look into it to see if it's blocking restricting applications running.
May 03, 2013 | Toshiba Satellite A215-S7422 Notebook
DVD drive won't open on my Toshiba Satellite U305 S7467
Insert a striaghtned paper clip in the tiny manual eject hole.
Dec 29, 2012 | Amstron Toshiba Satellite U305-S7467...
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
TOUCH PAD FOR TOSHIBA SATELLITE M840 SERIES WON'T WORK, HOW TO FIX?PLEASE HELP :)
Press the function key with the image(mouse/no mouse).For M840 its [ F5 ].
Try [ F5 ] or [ FN ]+[ F5 ]. For other pcs it maybe [ F9 ] .
Sep 02, 2012 | lf New Toshiba Satellite M800 M800D M801...
My Toshiba Satellite A215 - S7422 won't charge and
a problem with the battery or a charger.
Jul 17, 2012 | Computers & Internet
Satellite C660-2DL won't turn on
Hi
Try replacing the battery.
Also check whether it charges,could be a faulty charger too.
Feb 22, 2012 | Toshiba Satellite A60 Notebook
Toshiba Satellite L355-S7811 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
