Question about ViewSonic PJD5352 3D Projector
Viewsonic pjd5352 will not let me access menu to reset lamp timer
Lamp timer expired and comes up to view sonic screen with birds, then window pops up and tells me timer has expired and shuts down. It will not let me access menu. How do i zero the timer now
Marrie
  • 563 Answers
SOURCE: Not able to reset filter timer on ViewSonic
HI there
Scroll down to the filter timer in the Menu and hold down the right arrow button for a couple of seconds .
Posted on Apr 10, 2008
SOURCE: VIEW SONIC PROJECTOR IS NOT STARTING UP
Sounds like it needs a new bulb
Posted on May 05, 2009
projdoc
  • 2236 Answers
SOURCE: the projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Posted on Aug 10, 2009
  • 4 Answers
SOURCE: how to reset lamp timer on Pj458D
turn the projector on. open the menu. go to advanced. scroll down to the first option which should be auto source. make sure this option is checked. while on this option press right once, left twice, right 3 times, then left 4 times. another menu will appear. scroll to lamp time and push enter. this will take it back to zero.
Posted on Apr 01, 2010
heathgr
  • 442 Answers
SOURCE: HI I have a new View
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Posted on Apr 20, 2011
REMAINING LAMP HOURS
Press MENU on the remote (with the projector running of course).
In the window that comes up on screen, there are a series of icons on the left side of the screen, and the currently selected one will be highlighted (yellow if memory serves me correctly) scroll down through the icons to the very last one - the Information icon.
Press ENTER
The Lamp Timer (lamp hours) will now be showing on the screen, below technical info about the current signal feeding the projector. The 'Lamp Timer' information is at about the centre of the screen :o)
Mar 25, 2014 | Sony VPL-ES2 LCD Projector
Hi, I have a Panasonic PT-Ae900e Lcd projector,the lamp has now expired, the unit just shut down. Reading the manual it requires a reset of lamp runtime hours,as it shutdown itself we missed the corridor...
Check for lamp if it's properly installed. You must have screen on yor tv in order to reset lamp time(make sense ?) or your lamp is ok but ballast is burnt?
Hope this will help You
Aug 15, 2011 | Office Equipment & Supplies
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
The bolb come on then shuts down is there a manuel way to reset the lamp.
To reset the lamp timer you must be able to access the on screen menus. If you can't and the projector shuts down before you can do so then the lamp is unlikely to be the problem, howevere this is how you reset the lamp timer.
Turn the projector on, and press MENU
Press the POINT LEFT/RIGHT buttons until you get to SETTING and then press SELECT
Press the POINT DOWN button and a red arrow icon will appear. Move the arrow to the LAMP AGE and then press SELECT
Select YES to reset the lamp timer.
Feb 20, 2011 | Sanyo PLC XP30 Multimedia Projector
My view sonic monitor is turned on and then in a few minutes it turns off leaving me a black screen. what can i do to fix it?
Sounds like overheating of something inside. Open the monitor, get access to PCBs and observe for darkened areas especially over the power supply and inverter. Also that long working before shut down may tell about bad solder junction, also caused by constant local overheating - look for those with tiny cracks, especially over darkened areas on PCBs.
Most likely - that's the source of problem with your monitor. And, as far as you open the monitor, check for any popped electrolytic capacitor - never bad to replace them too.
Sep 14, 2009 | ViewSonic VX1935wm LCD Monitor
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
The projector would not shut down...it was not
Aug 09, 2009 | ViewSonic PJ556D DLP Projector
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
POST Replaced Bulb Problem, Error code = 32
This unit will not go into shut down because the lamp timer is not reset. The error you are getting means the lamp you put in is defective or it is not seated proplerly. Make sure the lamp door is on properly because there is a lamp door safety switch that must be depressed properly or the unit will shut down. When the timer needs to be reset you simply get a message on the screen that tells you so, it does not shut down. There are other things that will cause this problems such as the ballast or even problems in the light engine.
Apr 01, 2007 | Sharp 56DR650 56" Rear Projection HDTV
ViewSonic PJD5352 3D Projector Logo
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
