Question about Motorola Mobility MD761 Cordless Phone
Registering motorola L702 cordless handset - Motorola Mobility MD761 Cordless Phone
Registration
Hi Tom
Can you please tell me what the model of the expansion phone. I may be able to research anf find you the correct procedure for resistering a new address number to the phone.
Thank you
Greg
Nov 03, 2007 | Motorola Mobility MD761 Cordless Phone
L4 will not register to the base (L402C).This is an add on phone not the one that came in the L402C kit.
The directions to register the extra set are incomplete. I had the same problem. First push the find button on your base until the inuse light flashes. Then push menu on the cordless unit until it says please wait, make sure it says on the cordless unit to push the find button first, then place it in the charging cradle and it should register.
Sep 16, 2010 | Motorola Mobility L4 Cordless Expansion...
I have a Motorola L404 cordless phone. i bought an additional handset. I cannot get it to register with the base unit. It just keeps saying "registration failed"
On the Motorola L404 series, to deregister all handsets you unplug both the phone and power to the base station. Press and hold the 'find' button while plugging the power back in. The display will show "CL". Continue to hold the find button till the display shows '00' and all the handsets will show 'unregisterd'. You then proceed by registering all your handsets again in the order you want them listed.
Sep 01, 2010 | Motorola Mobility L4 Cordless Expansion...
How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
PROBLEMS with phone
Had the same issue. I have two units each with a handset, and one handset went to "out of range" status and stayed that way even after recharging. I tried to register it with that base and no luck. I then tried to register it with the other base and it worked. Then I tried to "swap" the handsets and no luck - it seems that the registration process on the one unit is toast so now I can only use the handsets with one of my two base units.
Oct 22, 2007 | Motorola Mobility MD7091 Cordless Phone
Registering handset problem
worked for us AFTER plugging/unplugging the base unit. thank you!
Feb 11, 2007 | Motorola Mobility MD761 Cordless Phone
Hooking up my phones
on the handsets, use the menu until you find register. It's pretty easy from there.
Dec 10, 2006 | Motorola Mobility MD761 Cordless Phone
Won't register
hi follow these steps and you will so great:( page 8) http://broadband.motorola.com/consumers/products/md7001/downloads/MD7001_Series_Users_Guide.pdf wont work try deregistering and then register again good luck
Apr 09, 2006 | Motorola Mobility MD7001 Cordless...
New Expansion Handset refuses to register with the base
If im not misytaking the base has to be set up for another expansion too.
Apr 06, 2006 | Motorola Mobility MD7091 Cordless Phone
Motorola Mobility MD761 Cordless Phone Logo
Top Motorola Mobility Lands Phones Experts
Motorola Mobility
Motorola Mobility
Ngoro
Ngoro
Beth
Beth
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
