Question about Garden
Belt Burning out
I have a 36" ride on mower. I've replaced the blade drive belt three times and I'm still have problems with the belt burning out while I'm driving the mower (not actually mowing). It seems to be burning out at the pulley attached to the engine. It is the same belt listed on the parts listing. I'm not looking forward to purchasing another mower. Does anyone have a good solution to fix this problem? Thanks
Why burning belt on 48" Craftsman riding mower
Since you mentioned "48-inch riding mower" let's assume your question is about the mower deck and not the overall mower or its main drive belt (if manual shift-on-the-fly model). If the belt burns that means it is running but slipping against something; or that the drive sheave us turning against an impeded belt. In the first case the belt will be burned along its length; in the second the burning will be occuring in one location(s) along the belt. In any case of belt slippage, check first that all tensioners (springs) are properly in place and not broken or fatigued and in need of replacement. The only other thing would be resistance to belt running, such as:
blade blockage; blade rotor resistance from lack of grease or ruined bearing in need of replacment; grass clogging on deck underside or under blade drive pulley on deck top side; a pully sheave out of round; an obstacle between belt and sheave that is preventing free turn of sheave and belt run; misrouted belt; an overstretched belt that cannot be sufficiently tensioned. Inspect and correct or replace as needed.
Aug 19, 2014 | Craftsman Garden
I recently replaced a worn blade belt on my poulan pro 42"deck riding mower. The mower is about 6 years old and has run great the whole time until the belt broke. The problem is that now the blades...
ill bet one of the blade holders has a bad bearing and doesnt spin freely. loosen the belt and check them all. some you can reoil but not all. good luck
Jun 17, 2017 | Garden
Smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
May 12, 2012 | Craftsman Garden
I am burning up deck belts on a 2 year old John Deere LA 105 mower
make sure the pulleys are free the check the arbor brakes
Apr 03, 2012 | John Deere Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
I have a troy bilt riding lawn mower and I followed the diagram on replacing the deck belt and it seems to keep rubbing something and burning the belt to smithereens. this has happened twice. have a brand...
Depending on which side of the belt is being rubbed is where I looked. If it is rubbing on the inside, I would suspect one of the blade being bound up and not turning.
If it is on the outside I would suspect something to do with the shield.
Jun 17, 2011 | Kitchen Ranges
The blade belt on my yardman yardbug smokes or burning whichever the case may be,why is this?
Either the blades are not moving due to a tight shaft under the mower deck, or a simpler malfunction, hopefully the belt just needs tightened by adjusting the pulleys.
Aug 13, 2010 | Garden
Eats mower drive belts
You say you checked everything. I would remove the deck and belt and physically make sure both blades spin freely. Then I'd install the belt and check again, it sounds as though each component works fine alone but when in conjunction with other parts something is binding. Good luck
Apr 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have replaced the drive belt linking to the two blades on my Rally ride-on lawn mower (92cm 5 speed 11.5 hp) and they are now cutting effectively. The problem I have is that the blades are still driven...
Here's what I have run into many times when all adjustments are correct. If it is not an original equipment belt after market belts vary in length. Which means most times they are usually a bit short. In this case you have two outs. One is to live with it which is not always safe and two get an original equipment belt from a dealer or the manufacture.Good luck.
Mar 24, 2009 | Garden
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
