Question about Bosch Water Heaters
Reset keeps triping
I have a aqua star 250sx lp water heater that the reset button keeps tripping. seems to be with high water flow. i have looked for a manual but no luck help
  • 700 Answers
Http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXTechSupport/Troubleshoot/tabid/563/Default.aspx
click on this link and it has the troubleshooting in strucktions for the unit . hopt that it helps you out.
Posted on Jan 11, 2009
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
Aug 23, 2012 | Water Heaters
Aqua star runs on and was running water to out side I guess it would be the overflow ( tankless). Had to turn the water off
Problem is not clear
Before calling service technician, open following link for Bosch troubleshooting resources including contact information for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 09, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Looking for a flow sensor for Aqua Star 240 FX
Here it is..
http://www.lowenergysystems.com/b2c/ecom/ecomEnduser/items/xt_itemDetailNF.aspx?itemNum=EK034&siteId=1&bulkexists=0
The Tagaki TK-1 is the same unit and the parts are interchangeable...
heatman101
Mar 16, 2011 | Bosch Water Heaters AquaStar - Tankless...
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
I have a 250SX aquastar Bosch tankless hot water heater . It keeps going out on EC code; whats wrong? Also I've been running the unit for about a 9 months without hooking up the condensate dain line.
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
No heat, no light, has flow and power?
I'm experiencing the samething it's been installed 3 years and christmas day nothing. Please help.
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
250sx quit working. Gas o.k. water flow good, throws ea code after 3 start attempts. 1. where is the ionization electrode, and is the fan supposed to come on before ignition? Fan comes on afterea code....
The gas pressure must be increased at the regulator from 9 inches of water column to about 12.5-13 inches of water column. The CO2 levels need to be adjusted for each installation. The air intake MUST come from outside the same wall as the exhaust. I have never seen any manufactures tankless unit installed properly. Plumbers do not read the manual.
Jan 24, 2010 | Bosch & Tankless LP Hot Water Heater
I have a aqua star 250sx lp tankless water heater that i have to keep resetting. seems to trip when the water flow is high i tried to look for a manual but no luck. help thanks brian
you should have no more then 75lbs of water pressure going thru the unit and min of 60lbs these are the pressures they are designed to work under, you may have to add a regulator to the system
Jan 11, 2009 | Water Heaters
Water Heaters Logo
264 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
