Question about Samsung HP-P4271 42 in. HD-Ready Plasma Television
Samsung hp-p4271 Close Captioning problem
As per the settings, the Close Caption shoud be functioning. It was on up until yesterday. For some reason, the Close Caption is not working. I have checked, and it works on the other TV's, so it is not the Satellite. So I ask, what could be the problem, or how can I fix it?
  • 133 Answers
There will be a button on the remote that says CC, hit that button, should probabily fix, if it doesnt, then there will be a defect on the main board
Posted on Jan 11, 2009
How to turn off closed caption
For over the air usually on the lower section of the remote look for CC or subt.
If on cable the Close Caption is controlled by the cable box not the TV. Usually there is a CC near the cable select button on the cable box remote. If not found then go into the cable box settings and look for
  1. Press the SETTINGS button
  2. Use the arrow buttons to scroll to the LANGUAGE section.
  3. Scroll to Closed Captioning and press the right arrow.
  4. Press the right arrow again and highlight the Off option
For some setups it is more complex. This link may help you with.
My Closed Captioning Won Turn Off
Jan 05, 2016 | Samsung Televison & Video
We get a black square on Fox and one children's cartoon network only. I have close captioning set off on my Uverse box menu. Is their anything else I need to do on the Olevia setup menu to eliminate the...
This is most commonly caused by the use of a Closed Caption text box. This type of Closed Caption is not always supported by the broadcaster, and results in the appearance of a black rectangle with scrambled or no text.
This can be quickly resolved by adjusting the Closed Caption type to "CC1" or by disabling the Closed Caption feature on your television.
get in the menu and change the close caption with the Olevia remote control
This should fix you right up
Dec 03, 2010 | Televison & Video
How to turn off the closed caption on the tv
Check the tv remote for a button that said CC.Used this CC button turn all CC1.2.3 ...to off.These will stop all the tv close captioning functions.Or check the tv Menu goto Close Captioning 1,2,3..close all to off,turn off all the text 1,2,3...to all off too.
Dec 01, 2010 | AOC Televison & Video
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
Black box on top of picture
This sounds like the text function is turned on in the closed captioning part of the menu. If the remote has a separate captioning button press that until captioning and text are off. Otherwise the caption/text settings are in the customer menu. Go into the menu to the captioning options & shut captioning/text off and see if this corrects your problem.
Nov 09, 2009 | JVC AV-27D201 27" TV
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
DV2150 Close Captioning
Same problem here.
Instructions for DV2150 say you can access closed caption toggle by going to SETUP, then OTHER then CAPTION, but this (CAPTION) option is missing from the menu. I, too am struggling with the Jeopardy game buzzers, which I cannot program. Was wondering if the lack of "closed caption" is the reason
Dec 28, 2007 | GoVideo DV2150 DVD Player/VCR
Closed caption
There are external close caption boxes that you can add to your system. But be aware: many cable boxes do not process the close captioning information "through", forcing you to use the close captioning on the cable box.
Dec 02, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Closed Captioning on HD channels
We had the exact same problem just yesterday when we bought our Sony 46" Bravia LCD. Nobody, neither Comcast Cable or Sony seemed to really know how to get rid of the closed caption at first and we did have a Motorola box - the box is the problem, not the tv. Here is step-by-step instructions that worked for us. 1. While TV is on, power DCT (Digital Cable Terminal) off 2. Press and hold "menu" button on digital terminal (the screen below will appear) 3. Using Up/Down cursors, highlight "Close Caption" 4. Using Left/Right cursors, put - Close Caption: Disabled 5. Press "ok-select" 6. When done, press "power" to exit menu 7. Press "power" again to turn DCT on If you go through these steps slowly, you should have a caption-free screen!
Jul 09, 2007 | JVC AV-48WP30 48" Rear Projection...
Samsung HP-P4271 42 in. HD-Ready Plasma Television Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
