Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Sucked a string up and now the self propel won't work
I was vacuuming and sucked a larger sting up in the vacuum and it caught up on the roller and now the self propel will not work and it will not pick up anything. any suggestions? Timi
  • 1,462 Answers
Re: Sucked a string up and now the self propel won't work
Because you caught up the string, the belt is perhaps broken. turn on and check the roller rotates
Posted on Jun 07, 2007
0 characters
3 Points
Sucked up a string and now roller isnt moving
turn the unit off and unplug it - get a razor blade - turn the unit on its side or back which is easier for you to see the bottom of the cleaner and the string wrapped around the ball and connecting area - use the razor blade to cut only the strings and remove the string from the ball
Jan 15, 2013 | Kenmore 23612 Progressive PowerMate Bagged...
I have an Electrolux upright with problems with the rollers. The reset switch that sticks out of the broke off several years ago and it worked fine. My wife sucked some string into the rollers and they...
Since the vacuum does reset, I suspect a different problem. If strings, hair, and similar items are picked up, they also wind around the ends of the brush, which would result in the roller being too tight to spin, thus shutting off the motor. You probably won't be able to see the ends without taking the powerhead apart. The problem with the consumer taking it apart is getting it reassembled correctly.
I do recommend getting the switch replaced, though. Take the vacuum to an authorized Aerus Electrolux store for repair and cleaning. Being an older one it probably needs it.
Jan 15, 2011 | Electrolux Epic 3500 Vacuum
I have a self propelled Power Supreme vacuum. It
Most common cause is fibre / hair in the roller and brushes. remove base cover and remove fibres . Remove screws and use small scissors to cut along roller / brush then pull gently.
Sep 20, 2009 | Vacuums
Self propel feature broke on Hoover Tempo Widepath
Sounds like the tie has loosened the belt off. You may have to check under neath the sole plate by removing screws and having a look. If the belt is broken it will have to be replaced. If its not broken check that it hasn't moved within the gear assembly of the self propel mechanism. Fit everything back together and it should work after that.
Feb 20, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Oct 11, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Need illistrated instructions on replacing belts on my self propelled hoover supreme
The flat belt probably has come off, may need to replace it if it hasn't been replaced in a while. May look ok, but am sure it has stretched.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum stopped in middle of vacuuming our carpet. Would not startup at switch. Tried other electrical outlets wondering if this was the problem and checked breakers, but it still did not go back on.
2 guesses.... One is that you vacuumed up a pice of cord or sting that got wound up on the roller (if it's that tyme of machine, and NOW everything's completelt "loced." Cure: look at the brush roller and "unwind" the cord or string.
Two is that you were doing it for a long time and the thermal circuit breaker (which is IN the vacuum cl;eaner itself) over heated and cut out. Usually these are self-resetting, so in a 1/2 hour or 45 minutes - when the thing coold down, it'll start working again.
Note that my first suggestion COULD cause the motor to heat up the and cause the thermal cur out.
Mar 17, 2008 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
184 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
