Question about KitchenAid 24 in. KUDP01FL Built-in Dishwasher
Reset Kitchen aid KUDI
Stuck on heavy cycle
5 Suggested Answers
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
  • 171 Answers
SOURCE: Kitchen Aid Dishwasher
Hi bluepanther,
I'm Harvey the Master Plumber.
Your problem is: You have a Kitchen Aid Dishwasher that has a light on saying CONTROL LOCK,of which when on you can't do any wash cycles.You tried doing canel out,but no help.What can you do to get off so can use unit?? Is there a reset button underneath that will reset unit.you are very mechanical and can pull unit apart if needed....Thanks Scott
Should not be nessessary. The lock is for keeping playfull little hands from getting into trouble. You must have inadvertently activated it. Try pressing and holding the "heated dry" button. This should deactivate the lock after about six seconds. This same procedure will reactivate it should you feel the need.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
  • 3 Answers
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: My Kitchen Aid dishwasher, model KUDK03FTSS3, is
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Posted on Oct 15, 2011
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
My kitchen aid K5SS won't run
first check the motor brush and replace them with a new pair. if you never do that check youtube and see a video how to do it.
Dec 05, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen Aid Manual for RRK90 mixer I need one
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen aide front loader washing machine won't finish cycle
On ours, i think that those codes were overload codes.. i had to go downstairs and turn the circuit breaker right off for about 5mins - when i clicked it back on, the washer reset.. i took some of the extra wet towels out and ran another wash with no issues..
good luck
tpug
Apr 27, 2009 | KitchenAid KHWS01PWH Global Horizontal...
KUDI01TJWH0 kitchen aid....the clean light is blinking and wont do anything else....how do we reset or do we just need to take it in for repair?????
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
Apr 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean cycle blue light **** on wash cycle won't start
try pressing stop/clear press and hold timer for 5 seconds this should reset the panel.hope this helps
Dec 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Hi bluepanther,
Thank you,
Sep 27, 2008 | KitchenAid Dishwashers
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid 24 in. KUDP01FL Built-in Dishwasher Logo
50 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
