Question about Pro-Fit Pro.Fit Pt 51 97 Pontiac Grand Prix 97 Up
Pontiac 97 grand prix
Too many lights on my car , CHECK ENGINE SOON , ABS , LOW TRAC, CHECK TIRE PRESSURE, car lost power after while on the road. and all these lights come out. and then car got off , put it in park and start running like nothing happen.
ANY IDEA WHY ???????
boris_20004@hotmail.com if someone knows why
Try having the mas air flow sensor checked out had the same prob and that was the prob.
Posted on Feb 01, 2009
The ABS lite, No Trac Lite and Service engine lite keep coming on
When the Service engine soon, ABS and TRAC lights are turned on at the same time the computer control units for the engine and the ABS/TRAC systems has sensed a fault in the electronic controls of the engine and/or the emission system and the ABS and Traction Control system (part of the ABS system). When this happens you will seldom feel the car engine run any different or the car drive any different. There are about 200 possible faults that turn the Check Engine light on, the fault in your car is likely a part called the VSS sensor to know for sure what the problem is you must have the system tested; Kragen and Autozone parts stores do this testing for free
Mar 22, 2011 | 2001 Pontiac Grand Am SE
As I was driving down the road, all at once 4 warning lights came on my dash at once (Check Engine Soon, Service Engine Soon, ABS, & Trac Off Indicators). What could be wrong, the car still ran fine...
It's most likely going to be the wheel speed sensor which is located at the wheel bearing. when they become disconnected or the wire breaks your abs and traction light will come on and something your check engine light.
Jun 14, 2010 | 2001 Pontiac Grand Am SE
Pontiac grand prix 99se ABS LOW-TRAC lights always on I bled system on all calipers nothing changed
have the ABS system checked with a scanner to get a trouble code then you will know where to look
Apr 05, 2010 | 1999 Pontiac Grand Prix
97 pontiac grand prix problem with the ABS, low
Get in touch with the "Better Buisines Bureau" or your state "Attorney General". Those people have a way of making dealerships like that listen. I can't believe they are telling you that it's not a safety issue, when the pedal goes to the floor. You could try a different dealer, or go to an independent shop.
Mar 18, 2010 | 1997 Pontiac Grand Prix
I have a 2000 pontiac grand prix... The Abs
the trac shuts off when theres a check engine light or a abs light on, most likely theres a bad abs wheel sensor but you will have to have the abs computer scaned to find out which one it is. hope this helps.
Jan 30, 2010 | 2000 Pontiac Grand Prix
Abs light, trac light, service engine soon light 2001 Pontiac Grand Am
Sounds like you have a bad wheel speed sensor. You need to have it scanned. Since it's been sitting, it might just be a bad connection to one of the speed sensors.
Jun 01, 2009 | 2000 Pontiac Grand Am GT
2004 Pontiac Grand Prix all warnings when starting the car
check all fuses and wires make sure everything tight.
May 26, 2009 | 2004 Pontiac Grand Prix
Abs and trac control lights are on
It is one of your wheel bearings. The problem is easily solved by taking the car to a dealer, or having a code reader, and determining which wheel bearing is bad. The wheel bearing is under $150 and should be installed by someone with some muscle, as the bolts are torqued from the factory extremely tight in a tight location. The wheel bearing have all of your sensors for abs built into them and if that sensor goes out your computer tells the abs and traction control to shut down, hence you get the lights on on the dash.
Jan 22, 2009 | 2001 Pontiac Grand Prix
Problem with my pontiac 97 grand prix
I suspect that your problem lies within the vehicle's ECC (Engine Control Computer). Prior to replacing it or having it tested, I would try re-setting it. You can do this by pulling the fuse (for good measure) to the ECC and disconnecting the negative battery terminal for thirty seconds.
During the time you have the power disconnected to the ECC, I would go ahead and check all the connections (make sure they're not only connected firmly, but also free of corosion). Electronic connector cleaner and a soft bronze brush (available at electronic supply stores) can be used to clean the connectors if necessary. After cleaning the connection, coat the wire ends with dielectric compound if it was used previously.
I believe the ECC for your vehicle is mounted under the hood on the passenger side wheelwell (front side of the strut tower).
Hope this helps and good luck!
Jan 10, 2009 | 1997 Pontiac Grand Prix
Pro-Fit Pro.Fit Pt 51 97 Pontiac Grand Prix 97 Up Logo
111 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Ottoniel
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
