Question about Symphonic SC3813 13 in. TV/VCR Combo
VCR isn't work, can you help?
Hi, Today I put a tape into my vcr and the tape got "stuck" after several attempts to eject it I finally got it out. Now it won't play anything. When I put a tape into it is sometime will run it for maybe 10 sections (if it runs all you see is bad snow) and then shuts off the TV. When I turn the power back on it ejects the tape. I've tried cleaning it but still run into this problem. Can you help? Thanks, Nancy PS: I'm very untechnical so would need to be walked thru with clear steps if you can help.
  • 934 Answers
Nancy, From the sounds of it either the supply or takeup reel is not working and may be damaged. In fact that may be the reason you couldn't get the tape out... If the takeup reel doesn't spin there is a small sensor below it that recognizes that there is a malfunction and shuts the system down. That's usually far cheaper than unloading a whole tape inside or do some serious damage. This unit is similar in design and electronics as the Funai F3813C and Sylvania 3813LC, W3813LC, Symphonic WS3813C and a Magnavox CCz132. That said, I have worked on a few of the comparable models for something quite similar and it has never been a real expensive repair. i'd guess this one would be under $80 dollars. Just find a reputable shop to take it to... If you not sure where to find one goto: http://www.nesda.com/locator/state_search.php and type in your info. That's the National Electronic Service Dealer's Assn. Kinda like going to the AMA to find a doctor... Good Luck Bill
Posted on Jun 07, 2007
VHS Stuck; Cover is off; nothing moves...wheels, tape...nothing...help
Unplug the unit, then plug it back in WHILE holding down the EJECT button ... The tape should come out unless there is a belt broken, missing, or loose.
I have used old, inoperable VCR's for tuners only as well. What happens if you leave the tape in all the time? Does the tuner work like that?
May 16, 2017 | Televison & Video
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Symphonic SC3813 13 in. TV/VCR Combo Logo
96 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
