Question about Woods 2C 24 Hour Indoor Mechanical Timer (59200)
Woods 24 hour indoor timer (50001) - Woods 2C 24 Hour Indoor Mechanical Timer (59200)
SOURCE: I have a Woods 24 hours indoor lighting timer. I
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
Posted on Oct 14, 2010
SOURCE: how do i program the
You posted under Woods indoor plug-in 24-hour mechanical timer.
This particular timer:
Rotate dial until current time lines up with words: 'time now' located on inner dial
To set on-off times, look carefully at dial that rotates.
There are tiny pins that stick up on the dial.
Each pin represents 1/2 hour.
Use fingernail and click pin outward for each half hour you want timer ON
Leave pins inward for each half hour you want timer OFF
Next, plug table lamp into side of timer.
Last step, plug timer into wall outlet.
If this is not your timer, see all Woods timers and manuals:
Or add a comment and I will help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Posted on Nov 18, 2010
SOURCE: I lost the directions for
Woods timers and manuals can be seen on link below:
Posted on Dec 13, 2010
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
SOURCE: Instructions on how to set the timer for my Woods
TD2200 is older version of 59377
How to change wood timer to 12h from 24h
Not all timers offer choice between 12 am-pm and 24 hour formats.
Download manual
Usually the 12-24 option is first step in programming after pushing reset button
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 15, 2014 | Woods Industries 59377 Indoor Digital...
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Dec 06, 2012 | Woods Hardware & Accessories
How do i program the 24 hour timer by woods?
Nov 17, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
Woods 2C 24 Hour Indoor Mechanical Timer (59200) Logo
331 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
