Hi Rich , what lights are you talking about ? Exterior Lighting ,
Interior Lighting ? It doesn't matter All lights are controlled by SJB smart junction box ! An you can't just stick in a used one , It will need to be programmed !
Interior Lighting
The interior lighting system consists of the following components:
- Smart junction box (SJB)
- Dimmer control switch
- Interior/map lamps
- Cargo lamp
- Glove compartment lamp
- Vanity mirror lamps
- Door ajar switches
- Puddle lamps
The interior lighting system consists of 2 subsystems:
- Courtesy lamps
- Demand lamps
The courtesy lamps are controlled by the SJB. The courtesy lamp subsystem consists of the interior dome lamps, the puddle lamps and the overhead console lamps (if equipped). The SJB supplies voltage to the courtesy lamps when the SJB receives the required input.
The demand lamps are controlled by the SJB. The demand lamps subsystem consists of the glove compartment lamp, all map/reading lamps, and the left and right vanity mirror lamps.
The SJB supplies power to the interior lighting system. The SJB will set DTCs if certain circuit failures exist with the interior lighting system.
Exterior Lighting
Headlamps
The headlamp system is a dual-beam pattern system. It consists of a low and high beam, with a replaceable bulb. The headlamp assembly has the park/turn indicator lamp integrated into the headlamp assembly. The smart junction box (SJB) supplies voltage to the headlamps when demanded.
Principles of Operation
The SJB receives inputs and delivers outputs to a majority of the electronically-controlled features of the vehicle. The SJB constantly monitors the systems under its control and reports a concern in the form of a DTC. The DTC can be retrieved with a scan tool through the medium speed controller area network (CAN) communication network.
NOTE: Prior to the removal of the SJB, it is necessary to upload the module configuration information to the diagnostic tool. This information must be downloaded to the new SJB after installation. For additional information, refer to Section 418-01 .
