Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Dirtlifter Powerbrush does not turn
I have the Bissell ProHeat 7901 series and I just bought it 2 days ago it worked fine to do my carpets and when I took it over to my parents house to shampoo there carpets I got the machine ready to shampoo.I turned the machine on and the brushes moved for about a minute then the brushes stopped.I opened the belt access door and the belt looks good and not broken. In my manual it says there is 2 belts a brush belt and a pump belt. Where is the brush belt and pump belt located.and which belt am I looking at when I remove the belt access door.Also how can I fix it so that the brushes work again. please help ASAP
  • Anonymous Mar 14, 2014
    brushes worked fine, heard a loud click then found small spring on the carpet. took steps contained in the manual but brushes still not spinning.could the spring be from the machine which is quite new
  • Anonymous Mar 28, 2014
    it appears to have all belts but brushes are not turning only manualy
    y
  • 48 Answers
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Posted on Nov 18, 2007
2 Suggested Answers
  • 8 Answers
SOURCE: Water will not come out to do floor work
UPDATE! I changed the pump on my Bissell Pro-Heat 7901-1. This corrected the problem.
Pipert
Posted on Dec 18, 2007
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
Model 7901-1 bissell proheat motor runs but won't squirt or ****, just quit 1/2 way thru carpet.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghd
Apr 11, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat model 7901-1 is there diagram of
I have pasted a link to the Bissell ProHeat series carpet extractor repair guide below. This guide is like my Bible when I'm working on these machines, and is EXTREMELY helpful on explaining how, and where hoses and parts go, and possible explanations of problems, and how to fix them.
I hope that this information is helpful to you, it sure is to me. If you did find this helpful, please be so kind and vote my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is what really keeps repair professionals like myself keep coming back and giving free repair advice, we greatly appreciate when people acknowledge our work here. Thank you ahead of time.
Bissell ProHeat Repair Manual
Thank you again,
Chris J.
GoVacuum.com
Apr 10, 2010 | Bissell 7901-R Clearview Proheat Plus...
How to use the bissell proheat Carpet cleaner 8910
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jan 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Apr 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
578 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
