Question about Nikon Coolpix S8100 Black Digital Camera2yr Warr ^
Nikon s8100 trash button stuck
Trash button is stuck
2 Suggested Answers
  • 1705 Answers
SOURCE: nikon coolpix s8100 will not turn on. i have only
If it won't turn on, you're not going to be able to reset it.
Other than sending it back, the only suggestion I can make is do you have or can you borrow a spare battery. If so, try that. It could just be a failed battery.
Posted on Aug 26, 2011
How can i fix a trash compactor that appears to have gone over limit switch
By over limit, do you mean it makes a knocking sound when the ram comes to the top and wont shut off until you press the off button? If that is the case, chances are the "Start" button (switch) is stuck in the closed passion. This is a mechanical issue with the switch that you might be able to clean the contacts and be done with it. The worse case is you'll have to replace the switch panel because you cant change the switches individually. If you do that will set you back about $100.00. I hope this helps, good luck.
May 26, 2014 | Kitchen Appliances - Others
Tip
Trash Compactor Problems Why it Does Not Work
Trash compactors can be a very nice feature and addition to your kitchen. However they can also be very hard to work on if they go bad. There are 20 some brands of trash compactors available, but the KitchenAid trash compactor is one of the most common.
If your trash compactor does not work at all here are some things that you will need to check.
First off make sure that you are getting power to the unit. Many are plug into by code a GFCI wall socket. These outlets do a great job of protecting against shock, but do a terrible job of staying on, especially when used on a motor that pulls a high amount of current when starting. It is not uncommon for them to go bad and trip for no reason at all after a few years. If the outlet is tripped, try to reset it by pushing in hard on the reset button in the center of the outlet.
If you have power at the outlet, then you will need to check through the circuit in the compactor. This can include a door switch, micro switches that sense the position of the ram, and possibly a key switch. Make sure that there is nothing stuck behind the drawer that would keep it from going fully shut. Check the position of the ram to see if it has returned all the way up.
If your ram is stuck down or if it will not go down, check for broken drive gears, belt, of chain. Make sure also that the switches that sense the ram position have not move and come out of place.
Your trash compactor will also need to be clean periodically. Food spilling on the tracks or glides can cause the drawer to slide hard or even become stuck. Clean all the slides or glides, wheels tracks and such with warm damp cloth and the re oil everything with a household lubricant. With time and use the wheels and bearings may also need to be replaced to keep your trash compactor operating well.
on Feb 28, 2010 | Kitchen Appliances - Others
Cannot get cd out. I think the dvd player is broken for good and the cd is stuck in the player. the only button that works is the on and off button.
Look for a small hole... if there is one, use a paperclip to press in the hole. It should help eject the CD. If that won't work and you are trashing the DVD player, you can always force the drawer open to get your CD out. Just pull on it or pry it open. You'll most likely break the track... so be prepared to trash it! OR you could take the screws out and take the unit apart... then you can get the CD out that way.
Oct 10, 2010 | Toshiba SD-5970 DVD Player
Stuck on boot screen
  • Hold the power button down untill it turns off
  • wait 30 seconds
  • turn it back on
  • at the "Think Pad" screen, hit the blue button.
  • try restore.
  • If that doesn't work, you may have a bad hard drive
Don't trash the computer or replace the hard drive without letting a tech look at it in person.
May 01, 2010 | IBM ThinkPad T43 Notebook
Remote is about shot out
It is time to go to radio shack, or staples, or walmart and purchase a universal remote. Once a remote's buttons start to act up like that you need to trash it.
Regards, Joe
Jan 27, 2010 | Sanyo DS27800 27" TV
Trash button stuck, how can I delete pics from camara & memory stick from computer
Go into your camera like you would your hard drive. Go to my computer then, look for your camera listed. Then there is usually a folder listed DCIM. Just look throught those folders. You will find the pictures. Then select them all by clicking and holding shift and delete.
May 09, 2009 | Cameras
Stuck on green mode cannot turn off
There is a small green button on the bottom right of the back of the camera. The trash can points to it.
Press that button. You will not delete anything and it will be taken out of green mode.
Apr 21, 2008 | Pentax Cameras
Nikon Coolpix S8100 Black Digital Camera2yr Warr ^ Logo
15 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
