Question about Lincoln Electric Foot Amptrol K870
I have ripped the plug off my k870 amptrol. What colour wires go where on the plug to be soldered...
This is off my 255 tig lincoln machine.
2 Suggested Answers
luis_david
  • 407 Answers
SOURCE: My K870 foot amptrol no
Hi:
Yes you can repair it yourself, the footcontrol has a micro switch that with time and use it wears out. Contact your welding sales rep or your nearest praxair store (www.praxairdirect.com) and request the micro switch, the sales rep will ask you for the code on the foot control, that one is on the plate on the footcontrol.
Good luck,
Posted on Jul 15, 2011
Diagram for multi plug, elkavox 83 generater to accordion
one wire coloured red is connected to the live line(soldered)
second wire blue in colour is connected or soldered to the neutral line.
third wire coloured green and yellow is connected to the earth line.
Jan 27, 2012 | Electrical Supplies
Lincoln precision tig 225. Makes bad aluminum welds in AC. Welds show signs of contamination. Have tried new argon bottle. No leaks in gas lines. Using pure and 2% thoriated tungsten, 3/32, pure...
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Sep 03, 2011 | Lincoln Precision Tig 225 Ready Pak With...
My K870 foot amptrol no longer lights off the welder. I jumped the "D" & "E" pin slots on the machine & it started, also can stick weld with that option which the tech support...
Hi:
Good luck,
Jul 14, 2011 | Lincoln Electric Foot Amptrol K870
Can the lincoln 305 d 1727-3 mig weld
If it has a setting for constant volatge, that is for wire feeders, flux cored or mig. Constant current is for stick welding. Some wire feeders have a switch to use them with a constant current machine, but that doesnt work very well, and , in my opinion, is hard on the computer in the feeder.
It looks like the ones we use in the field with a ln-25 wire feeder and flux cored wire. for mig you will also need a bottle of sheilding gas.
Jan 28, 2011 | Lincoln Electric Ranger 305D K1727-2...
Arc does not stop when foot control released
You need to get a diagram of the connector on the pedal, and check the contacts leads that trigger the power on. If the power on contacts are not opening up when you let up on the pedal then the problem is in the pedal, and you will need to open it up to find the problem. If the pedal is opening and closing as it should the problem is most likely in the welders control board. I just went through a similar problem on my Miller TIG, where the pedal wasn't the problem. If you have a bad board in the welder there are places on the internet that rebuild them, for much less than Lincoln would charge for a replacement. Try the two places listed below for circuit boards if you need them.
http://www.yorkelectronics.com/
http://gemelectronics.ieasysite.com/
Dec 18, 2010 | Lincoln K870 Foot Control For Tig Welder
Will not weld or arc , I bought my ranger after hurricane ke ask a generator, and never elded with it. today for the first time I tried to weld with it and it will not arc
Make sure the WELD TERMINALS SWITCH is in correct position.: In the WELD TERMINALS
ON position, the output is electrically hot all the time.
In the REMOTELY CONTROLLED position, the output is
controlled by a wire feeder or amptrol device, and is electrically
off until a remote switch is depressed. If you don't have your manual, you can download one at http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=104081
Jul 18, 2010 | Lincoln Electric Ranger 305D K1727-2...
My giant wse 200 tig inverter single phase AC/DC welder wont power up when plugged in have anyone got a wiring diagram.
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Sep 26, 2009 | Hobart Welders Champion 500433A Factory...
Hook up
I think I can help you do this, let's start with the general and you can ask questions if we don't cover everything you need.
The HF251D connects to the welding machine using 3 cables, you connect the Electrode terminal on the welding machine (the Lincoln) to the Electrode In terminal inside the HF251. Connect the Work terminal on the Lincoln to the Work In/Out inside the HF251, also connect the work (ground) clamp of your torch to this terminal. Be careful to select the correct size cables for the maximum current you intend to weld with.
The 3rd cable is the gray 14 pin round control cable that comes out the back of the HF251, it needs to be plugged into your Lincolns RMT14 socket. You'll also need to make sure that the Lincoln is set for remote control, this is usually a switch on the front panel. I'm pretty sure that the remote control cables have a standard pin layout, but we can check this by comparing the specs in both owners manuals.
After that you connect the torch and gas bottle to the HF251, start the Lincoln, and TIG weld until you're happy.
I've got a manual for the HF251 and can get a shop manual for it if we need it. What I'm not sure about is your Lincoln - what model is it exactly?
regards,
Carl
Dec 10, 2008 | Miller Hf 251D 042388 Tig Hi Freq For...
Lincoln Electric Foot Amptrol  K870 Logo
79 people viewed this question
Top Lincoln Electric Welding Tools Experts
Troy
Troy
Level 1 Expert
AZBen
AZBen
ka4iup
ka4iup
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
