Question about Compaq Keyboard
Solutions to fixing the top 12347890 keys - Compaq Keyboard
How do I fix FB? It has gotten so tiny that I can't read anything and is in the middle of the page. I am on a desk top computer.
You have possibly accidentally zoomed in by holding a key while scrolling. This page has some solutions for you
Sep 11, 2014 | Facebook Computers & Internet
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem my internal mouse is locked, I dont know why and dont know how to fix it (I dont use an external mouse or keyboard). ...
Hi melissamhahn..
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | HP Pavilion dv9000z Notebook
I buy a new lap top from curry.s and little problam in my one key ..in d...so plz u give me answer..can i use any spray ....plz send me solution....my d key is some time not work plz send me solution
You laptop is faulty. I suggest you return the laptop to the supplier to get a replacement unit or repaired under warranty. If you try to fix it yourself you will void your warranty.
Sep 01, 2011 | CMS (DELLX200200) 20 GB Hard Drive
E000-001-002 please help solution regarding this code
This a fixing assembly tempature error. First reset the copier by getting into service mode. Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, ERR, Then Ok. Power down copier then wait a few seconds then power up again. If the error continues then the fixing film will have to be replaced.
Jun 21, 2011 | Canon imageRUNNER 4570 Copier
12347890 keys are not functioning including its respective alt keys.
Try cleaning out your keyboard, it may be a mechanical issue. Canned air can help you do this.
You can also try plugging the keyboard into a different USB port.
If that does not work, the keyboard may just be broken.
Mar 01, 2011 | Compaq Keyboard
I have a Yamaha ydp-121 88-key piano. It has 3 keys that are sticking. Any ideas how to fix it?
I wrote up and photographed for my similar YDP, see solution 2 under this post:
http://www.fixya.com/support/t8881187-1_key_not_spring
Oct 20, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Keypad not working
sonyericsson w810i kiepad not working
Sep 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Microsoft digital media keyboard 1.0A
  1. Make sure there is no debris under the key - you can pop it off with a small flathead screwdriver. Clear any degris from under the key - use a cottonswab with a small amount of rubbing alcohol to clean any "sticky stuff"
  2. If that doesn't fix your problem, try downloading and installing the latest software for your keyboard: http://download.microsoft.com/download/6/f/2/6f207d9e-582c-4862-a631-8d20e91c5ff4/ITP32Eng6.20.182.0.exe Once installed, see if the button works now. If not try using the software to configure the key.
  3. If THAT doesn't fix your problem, then you might need to replace the keyboard.
Hope this helps! : )
Jun 10, 2008 | Microsoft Windows XP Home Edition
Broken key
Your best solution would be to buy a new keyboard for the laptop. Look on eBay for a replacement.
Nov 11, 2007 | Computers & Internet
Compaq Keyboard Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
