Question about Canon PIXMA iP1800 InkJet Photo Printer
Can't find any Deep Cleaning control
Where is the maintenance tab?
    Genius:
  • 1,011 Answers
Click this link
Posted on Jan 11, 2009
Clean the printer head
Go to Printers and faxes and right click on your printer and click on Properties - Maintenance tab - then select Cleaning or Deep cleaning
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 09, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
When I go to print everything looks good. The paper feeds through the printer but nothing prints on it.
Welcome to FixYa.
This problem might be due to blockages in the print head nozzles or if a FINE Cartridge is empty.
Kindly try the print head cleaning function to remove any blockages in the print head nozzles.
The procedure for cleaning the print heads, in the printer driver setup window (The printer driver setup window can be displayed through the application software in use or the Start menu of the Windows), is as follows:
Cleaning:
1. Make sure that the printer is on and click Cleaning on the Maintenance tab.
Print head cleaning starts.
2. Click OK when the confirmation message appears.
3. Next, the Nozzle Check dialog box opens.
To check whether the print quality has improved, click Print Check Pattern. To cancel the check process, click Cancel.
If cleaning the head once does not resolve the problem, clean it once more.
Deep Cleaning:
Deep Cleaning is more thorough than Cleaning. Perform deep cleaning when two cleaning attempts do not resolve the print head problem.
1. On the Maintenance tab, click Deep Cleaning.
The Deep Cleaning dialog box opens. Follow the instruction shown in the dialog box.
Click Initial Check Items to display the items you need to check before performing Deep Cleaning.
2. Make sure that the printer is on and then click Execute.
Print head deep cleaning starts.
If there is still no sign of improvement, the ink may have run out and the cartridges need to be replaced.
For more details, please download and install the complete on-screen manual from this link.
Thanks for using FixYa.
Dec 15, 2011 | Canon PIXMA MX310 All-In-One Printer
Ip4000 printer prints but with horizontal lines
Cannon recommend a cleaning process called deep head cleaning
  1. Open the Printers folder.
    - For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    - For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Deep Cleaning' icon.
  4. Select the ink tank color(s) for deep cleaning ('All Colors', 'Black', or 'Color').
  5. Confirm the message, and then click the 'Execute' button.
  6. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  7. Print a Nozzle Check Pattern by holding down the <Resume> on the printer until the Power light flashes twice to determine if further cleaning is necessary. Up to three deep cleanings may be necessary to determine if the print head is working properly
Sep 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Clean printer heads on Canon Pixma MP500
start - settings - printers and faxes
right click on canon printer - properties
click on maintenance tab
click on cleaning or deep cleaning
Jul 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Re Canon Pixma 4000 black ink is not printing colours are printing Computer not used for 6 months
Canno ip 4000:
please go to the maintenance tab.
This you will find if you try to print anything.
In the print box >go to properties>go to maintence
Here the following Maintenance option are there:
cleaning,
deep cleaning,
Head Alignment,
Nozzle check.
Before your start maintenance, please check whether all print tanks have ink in them
Do a Nozzle check first, this will indicate where you have the problem. Once identified, you can do a color cleanig or a deep cleaning.
Do a Nozzle check again.
You could repeat this cycle about three times or so.
If your problem still persists, then its probably the Print head with jammed nozzles.
Please let me know whether you could solve it.
Please do rate this solution and thanks for using FixYa.
Mar 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Hello, I work in a studio that has an HP officejet 4215 all-in-one, and although I did a partial reset, and restarted the computer as well, the printer will not print. Its' status on the computer says...
Try going into Control Panel
--> Printers and Faxes
--> Right Click on the Printer ICON and select Properties
--> Look for a "Maintenance" or "Tools" Tab across the top click one
--> Look for an option for "Cleaning" or "Deep Cleaning"
and click on one of these options to run
If you cannot find that then Try going into Control Panel
--> Right Clicking on your printer
Jan 30, 2009 | HP OfficeJet 4215 All-In-One InkJet...
My printer has a full black in cartridge, but the print is gray and blurry
Look for a maintenance or tools Tab across the top and try Cleaning or Deep Cleaning
Jan 25, 2009 | HP DeskJet 5740 InkJet Photo Printer
Refilled ink
Try checking under maintenance or ink settings, sometimes if the cartridges have been refilled they are not reset correctly and the ink level checking fails to work. There is sometimes and option to ignore these for refilled or compatible cartridges.
Control Panel
--> Look for an option for "In" or "Ink Settings"
Jan 25, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
Printless
Follow the steps below to perform Print Head Cleaning (Windows):
Note: After confirming that the cable is connected and the printer is powered on, perform the following.
    • For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    • For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  3. Click the Maintenance tab, and then click the 'Cleaning' icon.
  4. Click 'OK' to continue with the print head cleaning. The power lamp will flash and print head cleaning will start. Do not perform any other operations until print head cleaning completes.
  5. Print nozzle check pattern by clicking on the 'Print Check Pattern' button to determine if further cleaning is necessary.
  6. Once the page has printed examine the nozzle check pattern.
  7. If the pattern does not print correctly, click the 'Exit' button to return to the Maintenance tab.
  8. Click the 'Deep Cleaning' icon.
  9. Click the 'Execute' button.
  10. Confirm the message, and then click the 'OK' button to start the Deep cleaning.
  11. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  12. Print another nozzle test pattern. If the pattern still does not print correctly, replace any ink tank that may be low, and then perform another deep print head cleaning.
  13. If printing is still not satisfactory, there may be a problem with the print head.
Nov 26, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
22 people viewed this question
old marine
old marine
