Question about Sanyo DP42746 42 in. Plasma Television
Tv sensor not working ????
Have orig remote for tv and just stopped working. thought it might be remote so bought a universal... and then another one when 1st universal didn't work. tv mfg date is 03/2007... bought it new 06/2007. Any suggestions for arm chair "fix-it" mom????
Thanks
  • 362 Answers
Press and hold down the up volume button on the original remote, look at the light (led) on the remote, the light should be lit and slightly pulsing. If no pulse your remote is bad, if you are seeing the pulse try cleaning the ir window on front of tv. Let me know if this helps and please rate this solution. lone99star
Posted on Jan 11, 2009
G25819TK RCA tv (1991) aux jack problem
Without looking further you may need the Factory remote not all functions may be accessable using a "Universal" Ha,Ha,Ha remote.These Universal remotes have been problems in my line of work for years,Best idea is when you get a new tv pick up a cheap basic functions remote & use it for everday normal Vol./Channel/Power et. & keep the orig.for things the universal won't do
Jul 28, 2013 | RCA Televison & Video
I have a Sony tv that the Chanel display stays on the screen. I don't have the orig remote. Any thoughts on that. Thanks.
No universal will work for this, almost any Sony TV remote will with the DISPLAY BUTTON remove that--not too hard to understand, you have to have a Sony remote for any of their TV sets made in last 20 years that has the "display" to get this off the screen.
Dec 13, 2012 | Televison & Video
Problem with remote control or TV sensor? (Sanyo lcd32xr8da)
From your detailed description, I assumes that the infrared sensor inside your TV has the fault. This part can be loacated just behind the infrared sensor window at the front panel of the TV. You have to open the TV, and desolder it out from position, note the type used, and repalce it. There are so many types of these. Pictures of some are attached here.
6_13_2012_10_34_39_am.jpg6_13_2012_10_35_19_am.jpg6_13_2012_10_35_37_am.jpg6_13_2012_10_35_53_am.jpg
Jun 12, 2012 | Sanyo Televison & Video
My original remote with this model stopped working several months ago.I bought a phillips universal remote and that worked fine for several months and that stopped working.I bought a new Phillips...
The first possibility is that the new remote control is a dud out of the box. It can happen. Another possibility is that the remote sensor in the TV has failed. Then the remote is transmitting, but it's not being picked up by the TV. (The lights are on but there's nobody home.) If you can, return the new remote to the store and exchange it. Then, if the set still doesn't respond, you'll need to replace the remote sensor.
Jan 02, 2011 | Sylvania 4819LT 19" TV
My Scott Remote Control #KC01-B1 one night just would not connect to the sensor in my tv. I thought my batteries were low and changed them. The remote would still not work. I went to a Radio Shack...
Before you throw any more money at this problem, have you considered that the problem might be with the Infra-red (IR) receiver in the TV?
Also, did you programme the correct codes for your Scott TV into the universal remote/s? If you can let me know the model number/s of the universal remote/s - and you still have them - I can probably verify the codes and the programming instructions.
Hope this helps.
Oct 16, 2010 | Scott LCT37SHA TV
Can't get any remote to work for my Mitsubishi WS-7390573
You could always download a universal remote app from Google Play that should work. Hope this helps you
Apr 01, 2017 | Mitsubishi WS-73905 73" Rear Projection...
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Sanyo DP42746 42 in. Plasma Television Logo
492 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
