Question about Canon Office Equipment & Supplies
Can not receive Faxes from Canon MF4700
This machine is not hooked up to a PC it is used only for copying and Faxing. We have sent faxes but cannot receive them. Same telephone number is also used for other equipment ie postal scanner, credit card processor.
SOURCE: Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Posted on Feb 15, 2008
jtuminaro
  • 56 Answers
SOURCE: "poor line condition'
Very often this is caused by either the sender or receiver having VOIP phone service. Check this and if this is the case you need to set the baud rate to 9600.
Hope this helps!
Posted on Jan 15, 2009
  • 1126 Answers
SOURCE: Change number of rings before fax picks up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=14444
Look in the Advanced Guide for a possible solution on page 1-8 etc.
Posted on Jun 07, 2009
  • 4 Answers
SOURCE: Faxes do not send or receive using Magic jack
if its ooficejet,then u shud use 2 prong cable,wire that is coming out from wall jack shoud be directly connected to the line port of the printer and if u are using a tam that shoud be connected to the ext port of the printer,and if this doesn't work,then 1 thing you can do,remove the tam from the phone,and in case if you cannot remove,turn off the tam and then try to send,you wud be able to,and use only two prong cable,and i beleive you are not using voip connection....
Posted on Aug 25, 2009
  • 7 Answers
SOURCE: Cannot receive faxes on Canon Pixma MX870, but can send faxes
I was searching for an answer to this to make sure my new MX870 is correctly set to receive faxes. Here's one answer I came across:
First set Tel-Priority, turn off incoming ring, turn on manual/auto switch, then check how many seconds it takes for your answering machine to come on, and set it a couple of seconds after that. This should do the trick.
Posted on Oct 03, 2010
How do I fax using a cell phone and bluetooth?
Hi Gail
It's a little challenging as you need to configure a few things between your phone and the fax. These steps are basically one of doing it, but, I would resort to using the old fashion way! :-)
How to Fax Wirelessly Wireless faxing is easier today than it has ever been before. Whether you're faxing wirelessly from a tablet, smartphone, or computer, wireless faxing is pretty much as easy as sending an email.
There are three broad ways to wirelessly send a fax:
  • Use your cellular network
  • Use Wi-Fi
  • Wirelessly connect to a fax machine via Bluetooth or your wireless network
We're going to break down each of these faxing options down below and explain everything you need to know about wireless faxing.
Wirelessly Faxing Over your Cellular Wireless If you're trying to fax from your smartphone or tablet, then you're likely going to be faxing over a cellular connection.
There's only one way to fax over a cellular connection: online faxing.
Online faxing services act as a virtual fax machine. You communicate with this fax machine over the internet. That fax machine receives emails for you and sends them to your inbox. Then, you email the fax machine whenever you want to send a fax to a recipient.
With online faxing, there's really no restriction to the number of wireless devices you can use. As long as your device has an internet connection and the ability to send an email, you'll have no trouble wirelessly faxing over your cellular wireless network.
Aside from online faxing, there are no other ways to wirelessly fax over your cellular wireless network. You can't turn your mobile device into a modem. There's also no smartphone software that transforms your mobile device into a fax machine hardware platform.
Put simply, you can't receive faxes over the same number as your cell phone. It's impossible.
Using Wireless Internet (Wi-Fi) to Send a Fax Using wireless internet (Wi-Fi) to send a fax is as straightforward as sending it over a cellular connection.
The best option is to use online faxing. Online faxing lets you send a fax over Wi-Fi as easy as sending an email.
You sign up for an computer fax provider, then send an email just as you would normally send an email. Here's a quick step by step guide:
Step 1) Pick an online fax provider and sign up
Step 2) Compose a new email over Wi-Fi as you normally would send an email
Step 3) In the recipient section, type the fax number of your recipient followed by the online address of your fax provider, like by typing 1234567@nextiva.com.
Step 4) Add a cover letter to your fax by typing something into the body of the email
Step 5) Click "Send" after you've verified all of the information is complete.
That's it! You've just sent a fax over Wi-Fi using an electronic faxing service. If you're only sending a small number of faxes, then you might not even have to pay for faxing - many providers offer free trials or let you send a small number of faxes for free.
Alternatively, if you don't want to use online faxing, then you may be able to connect to your wireless fax machine over your Wi-Fi network (provided you're both connected to the same home or office network).
Some multi-purpose printers (with scan, copy, fax, and print capabilities) will have wireless connectivity.
Both fax machines and multi-purpose printers will also sometimes have Bluetooth functionality, which means you can connect to those devices outside of your wireless network.
Use a Fax Machine with A Wireless or Cellular Connection Some fax machines can connect to your home's wireless network over Wi-Fi, or they can connect to your computer over Bluetooth.
However, some fax machines go beyond this and connect to a cellular network on their own. These wireless fax machines are physical fax machines that have a dedicated cell phone connection.
These machines also go by names like GSM fax machines or CDMA fax machines, depending on the type of network they use.
If you use a wireless fax machine like this, then your fax machine will have a separate fax number and cellular service account. Faxes are sent and received over the cellular network just as they would be received using a traditional fax machine.
This type of wireless fax machine is ideal for situations where you don't have a phone line but have good cell service. These fax machines require a strong cellular connection, as any static or loss of quality on the connection may prevent the fax from being accurately transmitted.
These are all the ways to send and receive a fax wirelessly!
May 11, 2016 | Cell Phones
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
Unable to fax or receive faxes
Make sure the phone cord is hooked to the LINE OR FAX port.
Feb 16, 2009 | HP LaserJet 3055 All-In-One Printer
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Problem with sent faxes
CIS SCANNER SEEMS TO BE BAD TRY CIS TRAINING FUNCTION IN THE MAINTENANCE MODE AND DO CIS TRAINING USING A PLAIN WHITE SHEET/(FUNCTION *2864 , USE 55 CODE TO DO THE CIS TRAINING) OTHERWISE REOPLACE CIS SCANNER. HAPPY FAXING OMNIPRESENT
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
426 people viewed this question
old marine
old marine
