Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer Futura 350
My bobbin winder will not wind the thread onto the bobbin. I am working in sewing mode. It keeps giving an error message "E4". I have done everything according to trouble shooting for the manual and online support from the singer website. Can anyone tell me what I am doing wrong because nothing I try seems to work. Thank you. -Wendy
  • wwashingt228 Jan 13, 2009
    I did that already. More than four times and it didn't fix the problem. I stated that in my problem that I posted. I was hoping that someone else knew something else to try that would fix it the problem without calling singer support. -Wendy
    Scholar:
  • 110 Answers
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Posted on Jan 12, 2009
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
I keep getting error E5 when winding my bobbin
If you are winding the bobbin in the middle of sewing process, it is normal to get a notification (E5) that bobbin winder should be returned to the left position before continuing to embroider.
Jan 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Bobbins
When you engage the bobbin winder it has a small rubber in which it makes contact with the driver rubber maybe that is not making contact, to stop the cotton from showing on the top, adjust the small screw on the bobbin holder tighter clockwise.
Feb 26, 2009 | Singer CE-200 Quantum Futura Computerized...
I am trying to do letter embroidery on my Futura 350 and I keep getting constant error messages about thread breaking even when there is no visible sign of that. Also, the bobbin thread side is bunching...
Check out your threading with "Machine setup" Tutorial under Help submenu and whether the thread tension control on the front panel is set to "E".
P.S. The error message about thread breakage appears not only when the thread is really broken but if the sewing speed is not changing smoothly (for example if design is not optimised).
Oct 06, 2008 | Singer CE-200 Quantum Futura Computerized...
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
Bobbin winder is in operation mode
Try to change the bobbin winder position from left to the right and back again, probably it hasn't moved exactly to the proper position.
Check the version of the software and machine firmware under menu Help->About Futura. If you do not have the latest ones, you can update them through Live Update in the same submenu.
Aug 29, 2008 | Singer CE-200 Quantum Futura Computerized...
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Aug 18, 2008 | Singer Featherweight 140Q
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
636 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
