Question about Sony Playstation 3 (PS3) Console
Sony PS3, New power supply issue
You seem like the one that might be able to help me out. I too repair consoles of all types along with hardware and software mods. However this one has got me. This is my personal PS3, like many others I turned it on, started up Bad Company and then it popped and shut off. After checking power to the outlet, to the power cable and it wouldn't turn back on, common sense told me that it was the power supply. I had dealt with power supplies pleantly with the orginal xbox. So I bought a used one for it off of ebay. Installed it and now I get a red light, as soon as I touch the power button I get a green light then a second later the whole thing shuts down without lights. I turn off the main switch wait a minute and it'll do the same thing all over again (red light, green light, nothing).
I have read many post of this happing as well. So now I'm left wondering if this power supply has a fault too. I see that these switching power supplies have many different types of faults. I haven't ruled out the rest of the hardware, but without knowing wether or not I have a good power supply in hand I don't want to look away from it yet. If I do get my hands on a good PSU, I will take some readings to build a tester for them. Any insight you might be able to give will be greatly appreciated.
  • 3 Answers
There are two different things that i could think of that could be causing this problem. One being the main switch itself. try replacing that. and two the ps3 like almost everything does uses a disk based hdd and if it is dead or shorting out it will instantly turn off so you might want to check that.
Posted on Oct 09, 2010
My ps3 is automatic turn off when i turn on
It is basically a failure at the hardware level and is known to have a huge impact.
Some of the theories doing the rounds on what causes this specific error include power supply issues, lack of cooling or heat dissipation leading to over heating or drive errors. Lack of heat dissipation results in a hardware failure on the motherboard.
Improper power supply is another primary reason for the occurrence of YLOD. The general theory is that the console beeps whilst throwing the yellow light and then the console gives out a red light with the primary reason being over heat.
The probable reasons for this could be due to the various temperatures the system would experience whilst playing games and improper vents to provide the requisite cooling. Under such circumstances, it is recommended to leave the system unused until the heat is dissipated and the system cools down completely before turning it on.
Once you face the error, you have a few options to choose from:
• Buy a new PS3
• Get your PS3 repaired by Sony
• Get your Ps3 Repairs by someone else
There are a few temporary things you can do, but the over all will not last very long unless you open up your system... Your system needs to be cleaned.
Aug 15, 2012 | Sony Playstation 3 (PS3) Console
When I turn on my ps3 the fan runs for a few seconds then shuts off along with the green light.
It seems as a hardware problem, if you still have warranty you should contact SONY and they will replace your PS3 with a new one. Otherwise, you can try opening it and cleaning the fan if you feel comfortable with this or have an expert open it if you don't.Philip
May 25, 2011 | Sony Playstation 3 (PS3) Console
The red light is on on my ps3 but when i turn the power on the green light comes on then goes back off
That's is hardware problem.
Buy new motherboard and this will solve your problem
People think it is the power supply but it is not. Replace the motherboard and this problem will fade away.
http://www.ifixit.com/Guide/Repair/Installing-PlayStation-3-Motherboard/3493/1
Rate if you think this helped you.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
I trund on the playstation and then it went origeng then keeped on flashing red what do i do
Replace the power supply. This issue is known as YLOD (yellow light of death). Your power supply inside the unit has went out. You can pay Sony around $150.00 USD to repair it or you can open it yourself and match to a new power supply from E-Bay. They run about $40.00 on E-Bay and are very simple to install. Re-Post for more help!!
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on , blinking red light appears, any answers please
Hardware issue.
You can try booting the PS3 without the hard drive installed but in almost every case of the blinking red light it's related to the motherboard / power supply unit.
I'd recommend sending it to Sony direct for service.
1-800-345- Sony
You can check out this page or some tips / details.
Apr 03, 2010 | Sony Playstation 3 (PS3) Console
Consoles comes on for seconds then amber light comes on then the red light starts to flash
That's a hardware issue for sure. There isn't much you can or should try to fix this issue yourself...aside from removing the hard drive and power on the PS3. This almost never changes anything, but it's easy to do so it's worth a shot.
When that doesn't work you need to contact Sony direct for repair.
1-800-345-SONY
Hope this helps.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
My PS3 will not turn on. no standby lights no fan. i did not see the ylod, is it still the same problem?
HI, the internal power unit is damaged. it is no longer able to hold a proper current at this time. you will need to contact Sony for this repair asap, if possible.
Jul 09, 2009 | Sony Playstation 3 (PS3) Console
Is it difficult to replace the power supply in a PS3?
I Definitely Suggest you just buy a new power supply,,,, If your power supply fails, you can have multiple issues with your ps3... Being as expensive as they are... i would just say your best bet is to buy a new power supply... As for where to buy... Definately ebay... way cheaper!... make sure you check people's ratings before buying.... If you dont have access to ebay, then i suggest hitting up a electronics store that sells ps3's... if anything it can be ordered in... :D Good luck... Please rate! :)
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 crazy fan problem
Its a power supply issue you might want to exchange the PS3 for a new 1 at www.sony.com
Rate my Solution Please
I tried my best.
Apr 30, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power supply to console
BUT A NEW POWER SUPPLY OFF OF EBAY !!!!!! IT WILL COST YOU AT MOST 47.98 DO NOT PAY MORE THEN THAT .......!! TRUST ME DO NOT PAY SONY NOTHING 150 DOLLARS IS OUTRAGEOUS WHEN I KNOW FOR A FACT ALL THEY DO IS SWITCH OUT THE POWER SUPPLY UNIT ..THAT IS ALL THEY DO .....!!!!.....I HAD THE SAME PROBLEM ......I WAS PLAYING COD WORLD AT WAR AND THEN OUT OF NOWHERE IT JUST SHUT DOWN COMPLETELY ,..WHEN I TRIED TO TURN IT ON IT SHOWED A GREEN LIGHT FOLLOWED BY AN AMBER LIGHT QUICKLY TURNING TO A FLASHING RED ........I THOUGHT IT WAS AN OVERHEATING ISSUE BUT MY AMBER LIGHT SHOWING INDICATED A HARDWARE ISSUE SO I TOOK A CHANCE AND BOUGHT A POWER SUPPLY UNIT OFF OF EBAY AND RECEIVED IT WITHIN A WEEK .......IT BOOTED UP PERFECTLY FINE TRUST ME ...FOR GET SONY AND TRYING TO DO ALL THAT FANCY TRANSISTOR SWAPPING GEEK TALK BULL......JUST SWAP YOUR POWER SUPPLY UNIT AND THATS IT ...YOUR PS3 IS BACK ONLINE !!!!!!!!!!.....THATS IT BOTTOM LINE !!!!!!.....TAKE MY ADVICE OR LEAVE IT I DON'T CARE BUT I FIGURED I SHARE THIS WITH YOU GUYS SINCE I WENT CRAZY RESEARCHING WHY THIS HAPPENED AND I BASICALLY PUT COMMON SENSE INTO THE EQUATION TOOK A CHANCE AND BAMMMM!!!!! BABY I FIXED IT LOL..LOL...HOW ABOUT THAT ..FOR ALL YOU SO CALLED KNOW IT ALL PEOPLE OUT THER ..LOL..LOL.!!!!!...DAMN GEEKS TURNING THINGS INTO ROCKET SCIENCE ALL THE TIME .....LOL...........EBAY OR ANY OTHER PLACE YOU CAN GET YOUR HANDS ON ONE OK .........THANK ME LATER OK ..LOL.....TAKE CARE ..
Nov 04, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
511 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
