Question about Canon imagePROGRAF W8400 InkJet Printer
E02d03 printer starts with printing,than stops without reason,and show me on garo that usb conection faliled,when I shut power off,and on it is ok,but when I starts print again its same problem
Daniel9
  • 58 Answers
SOURCE: Can't print in Black ink
I had the same problem I found this solution to be very effective: * Buy alcohol solution (70% or more). You can find it in any drug store. * Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol into paper towel layer. * put the printer head on the top of wet towel with the face of HEAD touching the towel. * clean the head with the towel and get rid of all the built-up ink on the head. * Pour the alcohol into the printer head container (ink-receptacle area is where the ink cartridge normally sits, notice a small hole where the ink flow into the printer). Do not touch any electronic parts and let it dry over night. * Do step 2-5 again if necessary. * Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, make sure to repeat this step until no more dead nozzle shown. It worked for me :0)
Posted on Jun 27, 2007
SOURCE: prints black on test page, but not when a job is sent to the printer
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Posted on Nov 19, 2007
SOURCE: iP 4300 Canon Printer printing horisontal gray lines
To solve this problema, proceed with LF correction procedure, which is well documented on Canon IP4300 simplified service manual (it can be found at Emule network). This procedure prints some patterns and the user has to choose the best among them. One of them will probably enough to compensate (or, at least, to minimize the problem to the point that naked eyes can't observe it) the line feeding error which causes dark horizontal lines along the printer lifetime (probably because of feed roller wearing).
Posted on Aug 19, 2008
  • 18 Answers
SOURCE: what does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Posted on Oct 05, 2008
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
Posted on Mar 31, 2009
Everytime that I export to the ipf6100 plugin in cs6 it generates a crash report and will not print.
Process: GARO IOS Application [2876]
Path: /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
Identifier: jp.co.canon.GARO.IOSApplication
Version: 1.01 (1.01)
Code Type: X86 (Native)
Parent Process: launchd [201]
Date/Time: 2013-11-12 17:05:56.407 +0100
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 82539 sec
Crashes Since Last Report: 74
Per-App Interval Since Last Report: 497 sec
Per-App Crashes Since Last Report: 26
Anonymous UUID: C5192828-9918-4F37-8DAF-4C78AFC9A28F
Crashed Thread: 5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
__TEXT 0000000000001000-0000000000007000 [ 24K] r-x/rwx SM=COW /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
Feb 25, 2013 | Canon IMAGEPROGRAF IPF6100 InkJet Plotter...
Both of my ink cartridges went out at the same time and i only replaced the black. now it has an error saying it will not print because i need to replace the color ink cartridge. but i'm trying to...
It depends on the model that you have. You can try one of the following to reset the ink counter and the printer will show a full color cartridge.
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button
Aug 30, 2011 | Office Equipment & Supplies
Document failed to print
There are some printer order pending in your computer. For these reason you may to remove printer order. To cancel print order follow these proces
Start - printer and fax> printer icon double click> show window> then delete print order.
Now unpluge all the conection both usb and power. Wait few minites, and then reconect conection again
Thank you.a
Now , op,
May 19, 2011 | Office Equipment & Supplies
I have P2015n laser jet network printer. Since last two days garbage printing is contineously going on how to reset or stop this printing. Pl. give solution. Nitin Joshi adminnsk@ksb.co.in
1, Go to your services and restart Print spooler (start-run-services.msc) start stop it 2. Reinstall printer driver 3. Check your network or USB cable (depends how you have conected it)
Best regards
Mar 01, 2011 | HP LaserJet P2015n Printer
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
We have recently purchased the iPF8000S. When the printer is networked it pauses on each line of the print job. When the printer is connected directly to the computer with a crossover cable the printer...
cheers,
It may be a NW protocol/switch/router/driver issue. I print to my 8000s on USB 2.0, since the 8000s has no Gig E. But I had a few problems trying to connect to the Remote UI on separate network card with dedicated address. So in the end I left printer with dedicated address and plugged it into my el cheapo NW switch. The remote UI connected straight away via browsers URL to printers IP address. This way I can move files amongst mailboxes and rename them etc without affecting the print spools flowing via USB. Crossover cable should not be needed either on a modern device, since it should be more intelligent and realize the direct connection, auto switching pairs as needed. If you really need to drive 8000s on NW then I'd remove driver and try setting printer IP first via LCD, then forcing Garo driver installer to search and find the printer IP when re-installing its Garo driver.
Sep 14, 2010 | Canon imagePROGRAF iPF8000 Printer
My printer stopped printing in the middle of a job. do you know why?
Not without more information. The printer is fed from the pc on a USB cable. Anything that stops the flow of that information will cause the printer to stop printing. (Like shutting your pc off.) Also, the ink could have run out or a cartridge failed, the printer lost power or power surged, the USB cable disconnected or broke, the printer hardware failed. I'm sure there are more --
Aug 20, 2010 | HP DeskJet 810c InkJet Printer
I have connected d145 printer to my new dell laptop with Windows 7 but although installed as default printer it won't print
Do you have files in the queue? What is the printer status in Devices and Printers area?
Since this is a USB printer, my usual trouble-shooting starts with checking the USB connectivity. If you are using a hub, try connecting directly to the printer. Change to a new USB cable and try a different port. Check if a known working device will work in the port. Make sure the ports are not disabled for power-savings or security (power savings is adjusted as an advanced option in the same area as setting the Screen Saver, Security shut downs are in the Device Manager).
Frequently, you can reset the printer by unplugging the USB cable from both the computer and the printer and pulling the power cord for a minute. If the items in the print queue cannot be deleted from the queue, use the Command Prompt (run as administrator by a right click - Start, All Programs, Accessories) to empty the queue. Once in the command prompt, type "net stop spooler" without the quotes and then hit <enter>. Then type "net start spooler" (again without the quotes) and hit <enter>. Once the commands have been processed, reboot the computer.
I hope this helps.
Mar 25, 2010 | HP OfficeJet d145 InkJet Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
Upgraded to Leopard and now need to update my printer driver
Canon will not be coming out with a Leopard print driver for the W7250.
However, here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard:
1. Download garo34 print driver from Canon's support site here.
2. Download the iPF610/iP710 Leopard print driver from Canon here.
3. Double-click on the garo34_osx.hqx file that you downloaded.
4. A folder named Driver is created; open it and double click on "GARO Installer for X".
5. Enter a name and password of an administrator account on your Mac and click OK.
6. When the GARO Installer for X window appears, click on Continue.
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
11. When the installation is complete, click on the Restart button.
12. When your system has restarted, double-click on the iPF610_710_Driver_OSX_10.5_Ver1.10.hqx file you downloaded.
13. A folder named iPF610_710_Driver_OSX_10.5_Ver1.10 is created; open it and double-click on "iPF Driver Installer X".
14. Enter a name and password of an administrator account on your Mac and click OK.
15. When the iPF Installer X window appears, click on Continue.
16. Click Agree.
17. Click Install.
18. When the installation is complete, click on the Restart button.
19. When your system has restarted, click on the System Preferences icon on your Dock or select System Preferences from the Apple pull-down menu.
20. When the System Preferences window appears, click on the Print & Fax icon.
21. Click on the + Button underneath the Printers column.
22. Another window will appear; click on the "More Printers" icon.
23. A drop-down window appears; select Canon IP (GARO) from the pull-down menu if not already selected.
24. In the "Printer's Address:" field, enter the IP address of your Canon W7250 printer (e.g. 192.168.1.2).
25.In the "Queue Name:" field, enter a name for your printer (e.g. W7250).
26. Click on Add.
27. The W7250 is now your default printer. If you want another printer to be the default, change it in the Print & Fax preference pane.
Voila!
I hope this solves your problem and you found the instructions helpful.
Mark
Sep 11, 2008 | Canon imagePROGRAF W7250 InkJet Printer
Canon imagePROGRAF W8400 InkJet Printer Logo
48 people viewed this question
old marine
old marine
