Question about Sony KDL 46V5100 46 in. LCD HDTV
Sony KDL-46V5100 power supply
Low voltage in power supply
  • 8457 Answers
SOURCE: what swivel mount shouls i use for Sony BRAVIA
Tries Ebay.com to buy or go the Sony Website for info.to buy somewhere else.
Posted on Nov 23, 2009
SOURCE: HDCP not compliant after hook up
We have hooked up our Sony HD TV Bravia Model KDL-46v5100. when we hook up the DVI connectores the message says not
HDCP not compliant, what does this mean???
Posted on Jan 01, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: My Sony KDL-26S3000 won't turn on it well get stuck in standby
Please see the troubleshooting chart, BU1 board part # A-1268-869-A, cost approx $230.7685cfa.jpg
Posted on May 23, 2010
  • 5 Answers
SOURCE: Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Posted on Dec 06, 2010
  • 12 Answers
SOURCE: My Sony KDL-32M3000 has dark
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Posted on Jan 10, 2011
I have a sony KDL-46V5100 tv.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Aug 24, 2016 | Sony KDL 46V5100 46 in. LCD HDTV
My Sony Bravia KDL-46V5100 will not turn on. No red light bottom left corner
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony Televison & Video
Sony kdl-52s 4100 power supply ok but no sound and display
Well, if the power supply is in good working order, you will need to verify that the proper voltages are getting to the main board. If the main board is getting the proper voltages, I would bet you have a defective main board. The video and audio signals are generated on the main board. Expect to pay $100-$150 for a replacement main board.
Nov 24, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
I have a Sony KDL-46V5100, powers up but turns of right away
you have to check the power supply of the tv. If possible tyr to replace the electrolytic capacitors on the power supply board . sometimes bad electrolytic capacitors can cause such problems. Visually it would be ok . but while working it would malfunction. here added a video. it will help you understand how to deal with the power supply board. If you find the power supply is ok. the your tv need a new mother board.
http://electro-medical.blogspot.com/
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 13, 2012 | Sony KDL 46V5100 46 in. LCD HDTV
Kdl-46v5100 tv now dos'nt recognize hdmi.says no
Try another HDMI cable. I have seen them become defective. If it is not the cable, then try another HDMI device to test the TV.
Without an HDMI cable tester, and a way to measure the output of the HDMI source device the only way to resolve this is with the process of elimination.
Jerry G.
Jan 19, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
Dec 31, 2009 | Sony Televison & Video
What swivel mount shouls i use for Sony BRAVIA V-Series KDL-46V5100 46-Inch
Nov 23, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony KDL 46V5100 46 in. LCD HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
