Question about Dell Inspiron 9300 PC Notebook
Dell Inspiron 9300 VGA output to 46" Sony LCD problems
I have hooked the 9300 VGA and 3.5mm audio out to the TV VGA and 3.5mm audio in.
Can get the screen saver to come on the TV as monitor 2 but not anything else.
Video card is ATI Radeon Mobility X300 which I is set for dual monitor support.
  • dstaske Jan 26, 2009
    Thank you for your input, although I don't know what the F8 thing is about it worked, the video and audio output is to the tv and the laptop screen is blank.
    Thanks again
  • 88 Answers
Assuming that you have Audio already functional, the solution is to set your system to "Clone" rather than "Extend" video. Right click on desktop > properties > settings > click on second monitor > uncheck extend monitor box (below). Click ok, press Fn + F8 to Clone.
Posted on Jan 11, 2009
  • Biju Thomas Jan 27, 2009
    Nice to know that this fixed your issue. The Fn+F8 key combination is used to toggle the display from internal to external display. It has three states 1. On internal LCD only, 2. On both the displays 3. On External only... Pressing the key will toggle the states one after the other.
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How can i connect my dell inspiron 640m laptop to my sony bravia lcd tv?
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Feb 19, 2012 | Sony Televison & Video
When I started using Netflix, I hooked the Samsung Flatscreen TV up to my Dell Inspiron laptop via a VGA cable and it worked beautifully. Suddenly, the TV indicated that there is no signal. I checked the...
Most laptops have 3 video-display options:
* output only to internal LCD screen
* output only to external VGA port
* output to both LCD and VGA
Hold down the blue 'FN' key on your keyboard, and look at the BLUE labels on/above the 12 'F' keys. One of those Function-keys can be used to "toggle" through the above 3 display modes.
Jun 04, 2011 | Samsung Computers & Internet
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound)
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/pdf/UX8623D.pdf - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector. http://www.viewsonic.com.au/support/manuals/files/LCd%20TV/N2750w%20User%20Guide%20English.pdf
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Does my dell inspiron 2200 have tv o/p facility to the vga connector?
yes you have monitor out VGA connector just check left side of your laptop you can see 15 pic monitor output , that's VGA connector, you can use them to connect your lcd tv.
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | Dell Inspiron 2200 Notebook
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
Secondary monitor has no picture on Dell inspiron 9300
press Fn key along with the key that marked monitro on your keyboard together
Nov 07, 2008 | Computers & Internet
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Dell Inspiron 9300 PC Notebook Logo
345 people viewed this question
Alun Cox
