Question about Sport & Outdoor - Others
Need a service manual for york steller outdoor split system heat-pump model no.E4FH036S06
Need service manual so I can troubleshoot this unit
3 Suggested Answers
  • 12 Answers
SOURCE: York Heat Pump outdoor cutoff thermostat wiring.
You should call a professional in on this one you can damage alot of expensive parts trying to do this on your own without the proper tools and knowledge of the control logic
Posted on Sep 17, 2009
Testimonial: "OK...that's what I thought but figured I would attempt it myself, if possible. I will call my local heat/ac guys to install the cutoff switch. Thanks!"
MNfisherman
  • 11896 Answers
SOURCE: york manuals how does hvac zone york heating and
You can get the manual at york.com
Posted on Oct 26, 2009
What is F8 error in a westinhouse mini split?
Feature : F8 Error code on indoor unit display panel
  • Answer :Reason:
    Outdoor moter abnormal.
    Solution:
    This is usually be caused by the outdoor motor fault or outdoor PCB fault, and it couldn't be fixed by customer. Please call for service for help
May 03, 2017 | Heating & Cooling
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
What is the split pump
A split system has the parts split up between indoors and outdoors. A heat pump heats and cools your living space with the same unit. A split heat pump has the system split between indoors and outdoors and heats or cools your living space. a SPLIT PUMP sounds like something that has broken.
Feb 01, 2015 | Heating & Cooling
Need a wiring diagram for split system heat pump model number ch5536vkc2
need more information to help you.
1) is it single or 3 phase?
2) what power does it have? (example 30000 btus )
3) is it for the indoor unit or for the outdoor unit,? or both?
4) does it has an electronic circuit board in the indoor unit?
5) do you need only the field wiring diagram from indoor to outdoor unit?
Post me back with some details and I may help you out
Best regards,
Silvio
Dec 08, 2014 | Heating & Cooling
York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Apr 22, 2012 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Fujitsu split system not working
Hi, I know its a split as you have noted, and I am sure it would be a ductless heat pump system. Unless you are having a problem programming the t-stat, the manual would be of little help on these units.I wish you would have given more on the symptoms, like does it blow cold air or either unit will not work? You say it will not heat. On a H.P., it could be many things.Lets say its blowing cold air. Check the outdoor unit to make sure it comes on in the heat mode also, and the fan is on.Make sure you turn the heat up far enough to bring on the outdoor unit 1st. If it doesn't come on, then find the breaker to see if it is tripped. If yes, turn off hard and on again hard. if it stays on, great. If not, then It gets more complicated as compressor may have shorted out. Please check these things for me, please so we can solve this for you. On a heat pump, if you loose a compressor lets say, you have electric heat strips in the indoor unit that should come on if you have a switch on the T-stat that will say emergency heat. Try and use this setting to see if you can get some heat. I am trying to offer a solution to get you some temp. heat until we locate the main problem. If the indoor or outdoor units are not running at all, check for power at all breakers, and, check program on t-stat to make sure you set on heat, fan to auto, and temp to where you are comfortable.From here after checking all of these solutions, let me know what the status is and if it did not work, to tell me more of the original symptoms so I can go from there. Best of Luck,
Sincerely,
Shastalaker7
Nov 21, 2009 | Heating & Cooling
Need a manual for a LG split system
You should be able to get a service manual from the manufacturer online and down load it? Or go to where this unit was purchased and they should be able to help you.Get the model, serial, and product numbers from both indoor and outdoor units to take with you. The more info you have the better. The outdoor serial number shows the manufacture date.Have you removed the excess panel on the outdoor unit to see if a manual may be inside? they sometimes put them there instead of handing them to the owner. Good Luck!
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Sep 05, 2009 | York Yankees Bedding MLB Comforter
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
